It is currently Wed Feb 26, 2020 3:09 pm
 Post subject: Import of .gdc files
PostPosted: Tue Dec 25, 2018 11:27 am
Cannot import .gdc file using scripts.
Code given below...
#---------- Import handler class
class Handler(NativeImportHandler):
def conflict(self, name, obj, guid):
print("Object already exists: ",name)
return NativeImportResolve.skip
def progress(self, name, obj, exception):
print("in progess: ", name)
def skipped(self, list):
for obj in list:
print("Skipped: ", obj.get_name())
def importFilter(name, guid,type,path):
return True;
handler = Handler()
proj = projects.primary
found = proj.find("Application", True)
app = found[0]
##Select Ethercat
drbus = proj.find('EtherCAT_Master', True)[0]
Drive_1 = drbus.find("Drive1",True)[0]
if Drive_1:
Drive_1.import_native("C:\\Users\\Aritra\\Desktop\\Exported files\\Drive1.gdc", importFilter, handler)
else:
print("Drive Not Found")
