It is currently Sat Apr 20, 2019 5:18 am
PostPosted: Wed Nov 07, 2018 6:29 am
Hi!
I'm trying to create POU using python script in Codesys 3.5 SP5:
proj = projects.primary
found = proj.find("Application", True)
app = found[0]
print app
print dir(app)
# Create FB
mypou = app.create_pou("MyPou")
But I get the following error:
[WARNING]       Python 2 print statement found. For Python 3 compatibility, use 'from __future__ import print_function' and the print() function instead. in Script 'C:\Users\and-work\Desktop\1.py', Line '5' Column '1'
[INFORMATION]   1.py(1): Begin script
[INFORMATION]   1.py(1): proj = projects.primary
[INFORMATION]   1.py(3): found = proj.find("Application", True)
[INFORMATION]   1.py(4): app = found[0]
[INFORMATION]   1.py(5): print app
                ScriptObject{NoDeviceObject, NoExplicitConnectorObject, NoLibManObject, LibManObjectContainer, ScriptNoProjectInfoMarker, ScriptApplication, NoScriptApplicationComposerObject}(Project=0, Name=Application, guid=5a9278fe-989c-4674-9101-b9726dbde107)
[INFORMATION]   1.py(6): print dir(app)
                ['__class__', '__delattr__', '__doc__', '__format__', '__getattribute__', '__hash__', '__init__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__']
[INFORMATION]   1.py(9): mypou = app.create_pou("MyPou")
[INFORMATION]   1.py(9): exception (<type 'exceptions.AttributeError'>, AttributeError("'ScriptObject' object has no attribute 'create_pou'",), <traceback object at 0x000000000000002B>)
[INFORMATION]   1.py(9): exception (<type 'exceptions.AttributeError'>, AttributeError("'ScriptObject' object has no attribute 'create_pou'",), <traceback object at 0x000000000000002C>)
[INFORMATION]   1.py(9): return from script
Looks like there is no create_pou method in application object.
Could anybody help me with this issue?
Regards,
Victor
cron
