It is currently Fri Feb 22, 2019 7:13 pm
PostPosted: Thu Nov 01, 2018 7:50 am
Hey,
I'm trying to checkout a project from my SVN-repository, using the script engine/python. When I check out a Project a second time, codesys asks me, if I want to overwrite the older Version. I want to prevent this and want to tell codesys to overwrite the project via python.
Does anybody know, how that works?
Regards
Elias
PostPosted: Fri Nov 02, 2018 1:08 pm
Hey el_diep,
I have the same problem. I don't know how to overwrite.. But I have an alternative: before checkout the new project --> delete the old project. I am using this code:
myfile = (ProjectPath+"/"+your.project)
if os.path.isfile(myfile):
os.remove(myfile)
else:
print("Your.project is not available")
And now checkout...
I hope thats a good help until a moderator help us.
Chris
PostPosted: Tue Nov 06, 2018 3:19 pm
ChrisI wrote:
Hey el_diep,
os.remove(myfile)
else:
And now checkout...
Chris
Thanks Chris, that worked fine.
I hoped, that I didn't have to use such a solution. But temporary it's OK.
Perhaps a moderator might help us with another solution? :?
PostPosted: Fri Nov 09, 2018 9:40 am
Another nearly similar problem:
When there are any problems loading a project, there are Popups, too. Are there any possibilities to prevent this.
Popups in an automation-environment of an IDE are self-defeating :?
