https://forum.codesys.com/
Run python script in Codesys
https://forum.codesys.com/viewtopic.php?f=18&t=8734
Page 1 of 1
Author:  eamonn [ Thu Mar 29, 2018 1:09 am ]
Post subject:  Run python script in Codesys
I have a python script that sends a sms message to my phone when its run.
I want this code to run when a led in codesys turns on.
I can't figure out how to do this. I know that codesys can run python by using tools, scripting, execute script.
I just want the code to run automatically to alert me of an alarm.
Thanks for the help.
Author:  Edwin Schwellinger [ Fri Mar 30, 2018 7:06 pm ]
Post subject:  Re: Run python script in Codesys
this sms you want to send on an alarm or IO triggered by the plc and send by the plc
not in the CODESYS developmentsystem?
Because this python scription here is all in the CODESYS developmentsystem not in the plc.
If you need this for the plc side,
this example here should show how this could work:
(But this works only if the plc side could execute python...)
viewtopic.php?f=23&t=6247&p=19932#p19941
Author:  eamonn [ Thu Apr 05, 2018 8:24 pm ]
I am using the PLC to run the python code. It can run the code on it's own.
I cant seem to get my code to run. I don't have the hardware to test yours but I used your example to make my code.
It seems to run the code but it does not do anything. I have tested my python code on its own and it does work.
Author:  Edwin Schwellinger [ Sat Apr 07, 2018 7:12 am ]
so on which plc do you execute this?
Author:  eamonn [ Wed Apr 11, 2018 10:20 pm ]
I am running it on a raspberry pi 3 model B.
I am trying to have the single file run when a bool value = true.
I can't seem to get it to work through Codesys though.
Edit:
Never mind I got it to work.
Thanks for all the help though.
Author:  rKtiC [ Sun Apr 15, 2018 11:53 am ]
Could you specify how you made it work? I am trying to run a Python Script on a Raspberry 3 B with the _ and it does not do anything. Running the script via the command line works fine.
I would appreciate any help.
Author:  Edwin Schwellinger [ Sun Apr 15, 2018 5:46 pm ]
did you check this?
Author:  eamonn [ Sat Apr 21, 2018 6:49 pm ]
Here is the code that made it work.
This runs my python file sms_warning on the raspberry pi.
Make sure you do this
/etc/CODESYSControl.cfg:
[SysProcess]
Command=AllowAll
This can be done on the pi by using the command: sudo nano /etc/CODESYSControl.cfg
hope this helps.
Author:  Edwin Schwellinger [ Mon Apr 23, 2018 5:55 pm ]
one small remark:
I would recommend to move from /etc/CODESYSControl.cfg to /etc/CODESYSControl_User.cfg:
[SysProcess]
Command=AllowAll
This has the advanatage that on an runtime update ( for example from 3.5SP12 to 3.5SP13) this setting
will be retained.
Author:  Peter.skokanek [ Tue Jun 12, 2018 3:58 pm ]
I tried to use your examples to run my python script. But there is no /var/opt/codesys directory. I can find my PlcLogic/Application directory only directly in root directory. Where is a problem. Is it possible to set it somewhere in development system?
Author:  Edwin Schwellinger [ Tue Jun 12, 2018 4:59 pm ]
you need to update the Pi runtime Version to have it in
/var/opt/codesys...
Author:  jorgev [ Thu Aug 02, 2018 9:23 am ]
Hi all,
I would like to use this feature in Codesys (script lang) to transfer variable values between the PLC and a python script.
First, I am trying to execute a simple python script using codesys with a RPI 3 B+ as PLC. I followed the example posted for the unicorn hat as reference. However, I do not have the hardware to test it so I developed a simple code "print()" to verify the code is running.
Below the steps I have followed:
1. Add my script as external file in my CODESYS program.
2. Manually copy to the RPI my python script to the directory /var/opt/codesys/. I have also included
[SysProcess]
Command=AllowAll
in both files
3. Download the Codesys Program to the RPI and run the program from CODESYS.
Although I do not receive any error nor compilation or execution, I can not observe my code running. Is there any step I am missing or I should skip?
Thanks in advance
Author:  agrobot [ Tue Apr 23, 2019 12:00 am ]
I have the same problem, load the program well without errors, but do nothing, could someone solve this problem?
https://www.phpbb.com/
