It is currently Sun Apr 21, 2019 2:05 pm
PostPosted: Thu Jan 18, 2018 11:36 am
an invalid repository URL given to
svn.checkout
function leads to an exception.
How can this be handeled?
Is there a possibility to check the validity of the URL before call the interface function?
Thanks in advance.
Kind regards
D. Baur
PostPosted: Thu Mar 08, 2018 4:46 pm
we use the commandline option from TortoiseSVN with the subprocess module to check the path:
def svn_check_path(URL):
   command = 'CD C:\Program Files\TortoiseSVN\bin' # the shell command
   process = subprocess.Popen(command, stdout=subprocess.PIPE, stderr=None, shell=True)
   process.communicate()
   command = "svn ls " + URL
   process = subprocess.Popen(command, stdout=subprocess.PIPE, stderr=subprocess.PIPE, shell=True)
   #Launch the shell command:
   output = process.communicate()
   log = output[1].decode("cp1252");
   #Split the logs
   infos = log.splitlines();
   path_missing = False;
   for logs in infos:
      if 'warning' in logs or 'E200009' in logs:
         path_missing = True
   return(path_missing)
