It is currently Sun May 19, 2019 7:27 am
PostPosted: Tue Nov 28, 2017 3:31 pm
Hello!
Im trying to create a boot appl. with:
create_boot_application()
but every time i get this errormessage:
NameError: name 'create_boot_application()' ist not defined.
Could you help me please?
Thanks and best regards
MKeo
PostPosted: Tue Nov 28, 2017 4:27 pm
Hi MKeo.
The method create_boot_application() is only available on an online application object.
Here some example code for the active appliction:
onlineApp = online.create_online_application()
# login with download
onlineApp.login(OnlineChangeOption.Never, True)
# create boot application on the PLC
onlineApp.create_boot_application()
# logout
onlineApp.logout()
Martin
PostPosted: Wed Nov 29, 2017 7:37 am
Thanks!
There must be an other option to create a boot application, because I have an option to do it manually, where I dont have to be online or to log in.
Im want to make a boot application from IScriptApplication. There also is a boot application at IScriptOnlineApplication.
It just asks where I want to save the application, so I dont need to log in.
My problem is, that I need to create the .app and .crc files. Manually it runs without any problem, but I want to create those two files with a python script.
BR,
MKeo
PostPosted: Wed Nov 29, 2017 9:39 am
Yes, there is. Get the script object for the application you want to create boot applicaiton for and call the method create_boot_application(path) with the path for the application file.
Here some example code:
proj = projects.primary
found = proj.find("Application", True)
if not found:
   raise Exception("Application was not found")
app = found[0]
app.create_boot_application(r"c:\temp\myapp.app")
Martin
PostPosted: Wed Nov 29, 2017 9:58 am
Now it works!
Thank you very much!
