export/import devices
Nina
2017-10-20
2017-10-23
  • Nina - 2017-10-20
    I need to export and import devices from one repository to another. I can see the export option in codesys, but i do not find the corresponding option in ScriptDeviceDescrition
    to get the device I'm using this code:
    for id in range(0, DevRepList.__len__()):   # for some reaseon for Dev in DevRepList wont work
          if DevRepList[id].name == "X-Soft":
             XList=device_repository.get_all_devices(DevRepList[id])
             for  xDev in XList:
                pass # do export
    Is it possible at all to export devices?
    Thanks,
    Nina
    IMG: 1.JPG
  • mkeller - 2017-10-23
    Hi Nina.
    Nina hat geschrieben:
             for  xDev in XList:
                pass # do export
    About the first line of your code: Where does the come from?
    The export of device descriptions was added with CODESYS V3.5 SP10 and the Scripting API does not support it yet. I added an entry to our bug tracking so it will be implemented at some point.
    Martin
  • Nina - 2017-10-23
    M.Keller hat geschrieben:
    sorry, i forgot the first line:
    DevRepList=device_repository.sources
             for  xDev in XList:
                pass # do export
    Thanks for adding to jira
    Hi Nina.
    The iteration of should work. I tested it with the following code and had no problem:
    sources = device_repository.sources
    assert(len(sources) > 0, "no repo sources")
    print("Available sources of the device repository:")
    for src in sources:
       print("- {}: {}".format(src.name, src.location_url))
    count = 0
    print("Get all device descriptions from a specific source")
    sysRepoSource = sources["System Repository"]
    devColl = device_repository.get_all_devices(sysRepoSource)
    for dev in devColl:
       printDeviceDesc(dev)
       count += 1
       if count > 100:
          break
    You find the complete source code as attachment.
    BTW: You can get the repo source by name. The syntax for it is . It will return the matching repo source or if there is none with that name.
    Martin
    device_repo_show_minimal.py [1.74 KiB]
