It is currently Sun May 19, 2019 8:17 am
 Post subject: export/import devices
PostPosted: Fri Oct 20, 2017 1:22 pm
I need to export and import devices from one repository to another. I can see the export option in codesys, but i do not find the corresponding option in ScriptDeviceDescrition
to get the device I'm using this code:
for id in range(0, DevRepList.__len__()):   # for some reaseon for Dev in DevRepList wont work
      if DevRepList[id].name == "X-Soft":
         XList=device_repository.get_all_devices(DevRepList[id])
         for  xDev in XList:
            pass # do export
Is it possible at all to export devices?
Thanks,
Nina
PostPosted: Mon Oct 23, 2017 9:25 am
Hi Nina.
Nina wrote:
         for  xDev in XList:
            pass # do export
About the first line of your code: Where does the DevRepList come from?
The export of device descriptions was added with CODESYS V3.5 SP10 and the Scripting API does not support it yet. I added an entry to our bug tracking so it will be implemented at some point.
Martin
PostPosted: Mon Oct 23, 2017 10:38 am
sorry, i forgot the first line:
DevRepList=device_repository.sources
         for  xDev in XList:
            pass # do export
Thanks for adding to jira
PostPosted: Mon Oct 23, 2017 11:20 am
Hi Nina.
The iteration of device_repository.sources should work. I tested it with the following code and had no problem:
sources = device_repository.sources
assert(len(sources) > 0, "no repo sources")
print("Available sources of the device repository:")
for src in sources:
   print("- {}: {}".format(src.name, src.location_url))
count = 0
print("Get all device descriptions from a specific source")
sysRepoSource = sources["System Repository"]
devColl = device_repository.get_all_devices(sysRepoSource)
for dev in devColl:
   printDeviceDesc(dev)
   count += 1
   if count > 100:
      break
You find the complete source code as attachment.
BTW: You can get the repo source by name. The syntax for it is sources["some name"]. It will return the matching repo source or None if there is none with that name.
Martin
