It is currently Wed Mar 27, 2019 4:01 am
PostPosted: Fri Oct 06, 2017 8:49 am
Hi all,
I have some question about python for CodeSys:
1. How can I read all structure without knowledge of fields inside this structure using python?
2. Does CodeSys has some alternatives for tkFileDialog library? How can I create some dialog boxes for opening/clothing files?
PostPosted: Mon Oct 09, 2017 3:08 pm
Hi SashaSasha.
What do you mean with "read all structure..."? Read the online value through Monitoring or finding and reading the DUT objects?
Look in the Scripting API documenation for the interface/class IScriptUI which contains methods to open dialogs.
Here some example code:
print("Now, the user can select files and directories")
res = system.ui.open_file_dialog("Choose multiple files:", filter="Text files (*.txt)|*.txt|Image Files(*.BMP;*.JPG;*.GIF)|*.BMP;*.JPG;*.GIF|All files (*.*)|*.*", filter_index = 0, multiselect=True)
print("The user did choose: '%s'" % str(res)) # res is a tuple as multiselect is true.
Martin
