swtroelofs hat geschrieben:
Will it use native CODESYS Find and replace functionality, or do I just program a regex search in Python?
Not at the moment but you could use the IScriptTextDocument interface to search and change the Structured Text (ST) parts of the POUs.
Here some example code for finding the textual parts:
defgetFullName(obj):
  str=""
  whileobjisnotNoneandnotobj.is_root:
    str=obj.get_name()+'.'+str
    obj=obj.parent
  returnstrproj=projects.primary
\# Iteratethroughallchildrenoftheprojectforchildinproj.get_children(True):
  hasDecl=child.has_textual_declaration
  hasImpl=child.has_textual_implementation
  ifhasDeclorhasImpl:
    print("=== Object with text: {} declaration={} implementation={}".format(getFullName(child), hasDecl, hasImpl))
    ifhasDecl:
      declaration=child.textual_declaration
      print("Length of declaration: "+str(declaration.length))
      print("Content of declaration:\n<code>")
      print(declaration.text)
      print("</code>")
    ifhasImpl:
      implementation=child.textual_implementation
      print("Length of implementation: "+str(implementation.length))
      print("Content of implementation:\n<code>")
      print(implementation.text)
      print("</code>")
To change the content of a textual part you use the method . There are more methods you can use, see the Scripting API documentation.
Martin
Hi all,
I'm new to Python scripts and I am wondering if this is possible to script:
Before finishing a project I always run a couple of Find and Replace actions (with regex), for example:
Find: [\t ]+(\n)
Replace: $1
Can I make a Python script that automates this process? So it runs a couple of Find and replace actions in a row?
Hi swtroelofs.
Martin
