Utrehd - 2017-09-12
Hello all together
I have tried to run a script over batch file with this code:
@echo off
REM *******************************************************
REM Script launches Codesys and executes testDesktop.py
cd "C:\Program Files (x86)\Eaton\XSOFT-CODESYS-3\CODESYS\Common\"
XSOFT3.exe -profile="XSOFT-CODESYS V3.5.10" -runscript="C:\Users\E9955465\Work\MyProjects\Factory of the Future FoF\CodesysProjects\SolutionCenter\AE_StandardLibs\EA_MQTT\trunk\externals\Testing\testDeskstop.py"
@echo on
Or over
Codesys --> Tools --> Scripting -->Execute Script File...
I tried to run following script
testDeskstop.py:
print("Hello, automation!")
Both lead to the same error message.
Note: it is possible for me to run the same script over cmd with the ipy command.
Can you help me?
What could be the problem?
----------------------EDIT-----------------------------------------------
I found the problem and contacted the vendor eaton automation.
they will provide a bugfix.
with older version 3.5.8 it works but not with 3.5.10
Probably some problems with libraries they provoked.
This topic can be closed now
IMG: error.png
