https://forum.codesys.com/
Remove library from library repository by script
https://forum.codesys.com/viewtopic.php?f=18&t=8010
Page 1 of 1
Author:  DBaur [ Wed Jul 19, 2017 10:37 am ]
Post subject:  Remove library from library repository by script
How can a libary be removed by python script from the CODESYS library repository?
Can you give me an example for that?
Thanks in advance...
Author:  Hermsen [ Wed Jul 19, 2017 6:05 pm ]
Post subject:  Re: Remove library from library repository by script
I am also interested in such an example
Author:  M.Keller [ Thu Jul 20, 2017 9:19 am ]
Hi DBaur.
Here my example code:
print("Find library...")
found = librarymanager.find_library("TestLib, 1.0.0.0 (3S-Smart Software Solutions GmbH)")
if found:
   lib, repo = found
   print("Lib: " + lib.displayname)
   print("In repo: {} ({})".format(repo.name, repo.root_folder))
   print("Uninstall library...")
   librarymanager.uninstall_library(repo, lib)
   if found:
      print("Error: Lib ist still there!!!")
else:
   print("NO lib was found")
Martin
Author:  feragfh6 [ Wed Apr 04, 2018 7:29 pm ]
Hi Martin
Is it possible to find a library only by company?
So I can uninstall all libraries form one company.
found = librarymanager.find_library("*, * (Siemens)")
Thanks
Author:  XopHeT [ Tue May 29, 2018 3:24 pm ]
feragfh6 wrote:
Hi Martin
Thanks
I might be too late, but here it is:
#-*- coding: UTF-8 -*-
from __future__ import print_function
import sys, os
from sys import exit
libRepository = librarymanager
defaultRepository = libRepository.repositories[0]
def removeAllCompanyLibs(sCompanyName):
   sCompanyName = sCompanyName.upper()
   for repository in libRepository.repositories:
      for library in libRepository.get_all_libraries(repository):
         if sCompanyName in library.company.upper():
            system.write_message(Severity.Information, 'Lib removed: ' + library.displayname)
            libRepository.uninstall_library (repository, library)
   system.write_message(Severity.Information, 'Removing libraries done')
removeAllCompanyLibs ('siemens')
you might improve the line where library company is compared to your:
Author:  feragfh6 [ Wed May 30, 2018 11:06 am ]
Works. Thanks.
https://www.phpbb.com/
