It is currently Sun Nov 19, 2017 12:08 am
PostPosted: Wed Apr 19, 2017 9:34 am
For our controllers with more functionality (more time to compile and generate code) i have sporadic problems with the login function, which returns sometimes with an exception. It seems that there is a timing problem within the function:
Good case:
Skript Meldungen: Information: codesysServerScript.py(464 in download_and_run@443): online_application.login(OnlineChangeOption.Never, True)
Übersetzen: Text: C0: ------ Build started: Application: DeviceUnderTest.Application -------
Übersetzen: Text: C0: The application is up to date
Übersetzen: Text: C0: Kompilierung abgeschlossen -- 0 Fehler, 0 Warnungen
Übersetzen: Text: C0: generate code...
Übersetzen: Text: C0: generate global initializations ...
Übersetzen: Text: C0: generate code initialization ...
Übersetzen: Text: C0: generate relocations ...
Übersetzen: Information: C0: Size of generated code: 77820 bytes
Übersetzen: Information: C0: Size of global data: 16318 bytes
Übersetzen: Information: C0: Total allocated memory size for code and data: 120272 bytes
Übersetzen: Information: C0: Memory area 0 contains Data, Input, Output, Memory and Nonsafe Data: size: 131072 bytes, highest used address: 42432, largest contiguous memory gap: 88640 bytes (67 %)
Übersetzen: Information: C0: Memory area 1 contains Code: size: 131072 bytes, highest used address: 77840, largest contiguous memory gap: 53232 bytes (40 %)
Übersetzen: Text: C0: Build complete -- 0 errors, 0 warnings : ready for download!
Bad case:
Übersetzen: Text: C0: typify code ...
Skript Meldungen: Information: codesysServerScript.py(464 in download_and_run@443): Ausnahmefehler (<type 'exceptions.Exception'>, Exception('Einloggen fehlgeschlagen...',), <traceback object at 0x000000000000008E>)
For workaround i run the function 3 or 4 times in a row.
It never happend with the GUI.
PostPosted: Wed Apr 19, 2017 10:57 am
Hi PLKM.
Bad case:
Which version of CODESYS do you use? Is the project just loaded before the login?
Instead of repeating the login you can try to add a delay with system.delay(x) before the login. For the start I would use 5000ms and reduce it step by step if it works.
Martin
PostPosted: Thu Apr 20, 2017 1:05 pm
I use SP10 Patch 1 and there is no interaction with CODESYS at least 15 seconds before the login method.
I already tried it with System.Delay(x) before the login, but the failure still exists.
If i pregenerate the code with the generate_code() method it seems to be better, but the failure is still available sporadically.
PostPosted: Fri Apr 21, 2017 11:06 am
Hi PLKM.
You can try to use RaiseIdle() in combination with system.delay(). There are a few things in CODESYS which are executed with the Idle event. Call RaiseIdle(EventArgs.Empty) and system.delay(500) a few times before the login.
If that does not help we could have a problem in the noUI mode which we need to investigate.
import clr
clr.AddReference("System.Windows.Forms")
from System.Windows.Forms import Application
from System import EventArgs
Application.RaiseIdle(EventArgs.Empty)
What is your Use Case for using the noUI mode?
Martin
PostPosted: Wed May 03, 2017 10:21 am
M.Keller wrote:
Hi PLKM.
import clr
Martin
The RaiseIdle Method seems to help. I will do some more tests in the next days.
The noUI mode is for automated tests for our controllers, which are running in the background.
