It is currently Tue Oct 17, 2017 1:15 am
PostPosted: Tue Mar 14, 2017 3:23 pm
Hi there,
I wonder if it is possible now to set up the gateway and device by IP address and device address?
I have looked up on the forum and in the ScriptEngine.chm. The only way I found was to use the device name, shown below.
Quote:
projects.primary.find("Device name", True)
get_gateway()
get_address()
set_gateway_and_address(gateway, address)
Thank you in advance :D
PostPosted: Tue Mar 14, 2017 5:50 pm
Hi chenhe.
With CODESYS V3.5 SP9 or newer you can use the method set_gateway_and_ip_address(...) to specify the IP address for the device.
You can find your gateway object by its name with the following code:
gw = online.gateways['Gateway-1']
If you don't have a gateway you can create one with online.gateways.add_new_gateway(...). You need to create a dictionary with the parameters required by the gateway driver. Each parameter must be converted to match the required type in the driver. I can provide an example if you need one.
Martin
PostPosted: Thu Mar 16, 2017 9:26 am
Hello M.Keller,
I'd like to have the example for creating new gateway. Thanks again. :D
PostPosted: Thu Mar 16, 2017 12:21 pm
Hi chenhe.
I attached an example for creating a gateway.
Martin
