It is currently Fri Jul 28, 2017 1:43 am
PostPosted: Tue Mar 14, 2017 1:26 pm
I have a project with two applications which are not at the same level in project tree.
How can I manage connexion in each of these two applications independently in Python script ?
Can I connect and force variables on both applications or do I need to use something like the command menu "define active application" ?
Can I set the active application using python script ? Which is the method to use ?
Thank you
PostPosted: Tue Mar 14, 2017 2:46 pm
Hi Nicolas233.
The operations for connecting to an application and reading/forcing variables from it are part of the online application object which you get by using online.create_online_application(). You can call the method with the GUID of the application object or the application object itself to get the online application object for the specified application. See the attached python script.
If you want the online application object for the active application or if your project only contains one application you can call the method without a parameter.
Martin
PostPosted: Wed Mar 15, 2017 1:52 pm
Hi Martin,
Thank you for this example.It's helpful.
However, my script encounters an error when i use such scheme.
The error message is :
Quote:
Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
It seems to happen on the following lines :
app = found[0]
Do you know where i can found inputs and outputs définitions for methods such as proj.find or projects.primary ? I don't find any description and, or examples in Script Engine API reference and in Python documentation. Where should I search ?
I think the line :
found = proj.find("Device", "PLC Logic", "Application")
is used to get the application GUID, isn't it ?
How can i get GUID of an application from the application name in the Codesys project tree ?
Thank you
PostPosted: Wed Mar 15, 2017 2:34 pm
Hi Nicolas233.
app = found[0]
If found[0] creates that error than you didn't find any objects with the specified name or the specified path (array of names). I used this variant of the method find(...) so I can specify the complete path of the object.
The documentation of the Scripting API is in the file "ScriptEngine.chm" which is in the sub directory "Online Help" of the CODESYS directory. With CODESYS V3.5 SP11 we will add an introduction to the ScriptEngine/Scripting to our Online Help.
Nicolas233 wrote:
I think the line :
No, it is used to specify the complete path of an object. If you used proj.find("Application", True) and you have more than object with the name "Application" you get an array with more than one entry.
All script object of the project tree have a property guid which return the GUID of the object. But you don't need the GUID of the appliction to use online.create_online_application(...) because you can also use the script object of the application to get the corresponding online application object.
Martin
PostPosted: Wed Mar 29, 2017 12:28 pm
Thank you for these explanations. It helps me to correct my script.
