It is currently Thu Jul 27, 2017 1:38 pm
PostPosted: Thu Mar 02, 2017 2:13 pm
after adding a profinet slave(siemens et200s) to my pn-controller via script i want to get online and start the app. Then the following error occurs:
"Stationsname" and the other Parameters are correct. i can fix the problems manually by Clearing the textfield and type et200s again OR i deactivate the unused Slot (<leer>). i tried deactivate the unused Slot by script too, but that didn't work.
I hope somebody can help
Steffen
EDIT:
After some test I recognize that I can fix that to if I manually stop and log out. Then I doubleclick on the treeobject et200s just for open the Dialog. Then I log in again and start and it works.... The following Dialog opens by Login in:
by clicking JA and start it works...
PostPosted: Fri Mar 03, 2017 8:16 am
Maybe some more Infos...
Before and after I log out, doubleclick the treeobject and log in again, I print the device and hostparameters for compare. Before I do the log out..... the parameter id=1025 Name=SlaveOptions is missing. After I doubleclick et200s I run the script for printing the Parameters again and the parameter 1025 appears and the System runs.
Is it possible to ad the parameter or do this steps by script?
I attached my code
PostPosted: Mon Mar 06, 2017 4:06 pm
Is it possible that i have to declare the device as a slave? If yes, where?
