It is currently Thu Jul 27, 2017 1:39 pm
PostPosted: Mon Feb 27, 2017 4:16 pm
I have the following code in an enum declaration:
// | Acknowledge Control Byte
// Implemented according to:
// * SAE
//     * J1939
//         * -11
//             * Figure 9 - Acknowledgment Parameter Group Number Definition
// .. note:: This data/ parameter type is used in the ACK parameter group.
I have tried around with the indentation of the unordered list, but did not get a tree as a result. Sometimes the indentation in the output is there, but the bullets are missing. In other cases the lines are all or groupwise written in one with a * between the points.
What am I doing wrong?
Thanks in Advance
Torsten Knodt
PostPosted: Wed Mar 01, 2017 11:12 am
Hi Torsten.
Every time you start a new sub level in your list you have to add an empty line before and after it. See Lists and Quote-like blocks from the reStructuredText Primer.
// * SAE
//     * J1939
//         * -11
Here the screenshot:
Martin
