It is currently Wed Oct 18, 2017 4:58 am
PostPosted: Fri Feb 10, 2017 9:12 am
Hello everyone,
I've just subscribed in the forum to get help in a script that I'm writing, I have two questions for you, I hope you could help me.
1. I want to add/insert a device in the project but the method needs the DeviceID as parameter, what I know it's just the Order Number. I've seen something helpful in the file devicecache.xml but, is there an embedded method to get the association between Order Number and DeviceID?
2. I want to add/insert a bus slave, how can I know the right bus master that I have to add to the controller? Or alternatively, can I have a list of slaves that I can add to a master in the project? In other words, is there something that help me to know the admissible devices in the master/slave hierarchy?
Thank you very much!
Best Regards,
Daniele
PostPosted: Mon Feb 13, 2017 11:47 am
About the second question, I've found in the help the IScriptModuleRepository Interface that seems helpful but I didn't understand who implements it. Can somebody explain me how to use that interface and its methods with a simple example?
Thanks in advance.
Best Regards,
Daniele
PostPosted: Tue Feb 14, 2017 11:02 am
Hi Daniele.
Open the device repository (Menu Tools->Device Repository), select a device and click on the Details button. In the dialog you can find the necessary information to add/update a device. See the marked parts in the attached screenshot.
Here some example code for adding a device:
proj = projects.primary
# Add PLC to an empty project using a DeviceId instance
devId = device_repository.create_device_identification(4096, '0000 0001', '3.5.9.0')
proj.add('Device', devId)
found = proj.find('Device', False)
device = found[0]
# Add Ethernet device using the type, ID and version instead of a DeviceID
device.add('Ethernet', 110, '0000 0002', '3.5.9.0')
ethernet = device.find('Ethernet', False)[0]
ethernet.add('ModBus_Master', 88, '0000 0003', '3.5.9.0')
master = ethernet.find('ModBus_Master', False)[0]
master.add('ModBus_Slave', 89, '0000 0005', '3.5.7.0')
slave = master.find('ModBus_Slave', False)[0]
Open the context menu of the parent device and click on "Add device". The dialog lists only the devices which can be added below the selected device. If you select an other device the list is updated.
The IScriptModule* interfaces have nothing to do with devices. They are from the CODESYS Application Composer. Modules are part of a device and some devices have "slots" where their modules can be plugged in. The slot objects have a method plug(...) and unplug(...) to add and remove the module.
Martin
PostPosted: Tue Feb 14, 2017 11:36 am
This is the UI solution, I would like a scripting solution if exists.
device = found[0]
You are still using DeviceID and it doesn't help me very much.
Yes, I know, this UI behavior is exactly what I would like to reproduce by scripting.
Ok, thank you.
Once again, how to know the modules which can be added to a specific device?
Sincerely,
Daniele
PostPosted: Tue Feb 14, 2017 1:10 pm
Hi Daniele.
What do you want to accomplish? What is your Use Case?
You can access the device repository through Scripting and search for a device. If you only have the order number, you can iterate through all devices and check for it.
Martin
PostPosted: Tue Feb 14, 2017 2:39 pm
Hi Martin,
I have an order number of a device that I want to add to the controller in the project. First of all I need to pass the DeviceID to the add() function but I don't know it. The second problem I have encountered regards the hierarchy between devices, for example if my device is a bus slave I need to add the compatible master first.
About the Device Repository, I can't use it because I'm working on SoMachine v4.31, the Schneider Electric software, actually based on Codesys v3.5.5 . Do you think it can help me? In few months a new version of SoMachine will release and maybe it will implement the device repository.
Best Regards,
Daniele
PostPosted: Thu Feb 16, 2017 10:08 am
Hi Daniele.
With CODESYS SP9 we introduced a Scripting API for the device repository but it does not provide the information you need for your use case.
You have to parse the device cache and build your own data structure which contains the device and its connectors and interfaces. In the list of devices you can search the order number if it was specified in the device description. Through the connectors and interfaces you can find one or more possible parent devices. You may have to add some code to decide which parent device is the most suitable or the only one you want to use.
Martin
PostPosted: Thu Feb 16, 2017 10:41 am
Mmmh... ok
Thank you Martin, I'll go in that way.
Daniele
cron
