It is currently Thu Jul 27, 2017 1:37 pm
PostPosted: Fri Feb 10, 2017 8:53 am
When a library is compiled by "Check all pool objects" from Build-menu and there occure build errors (which are displayed in die Build message window) it is nevertheless possible to save the library as "compiled library" - why?
How can build/compile errors be detected in a python script if the "Check all pool objects" command is also triggered by python script?
Thanks in advance.
PostPosted: Fri Feb 10, 2017 11:35 am
Hi DBaur.
Why don't you use the method check_all_pool_objects() of the project object?
Here some example code which "builds" a loaded library and prints the compiler error:
CompileCategory = Guid("{97F48D64-A2A3-4856-B640-75C046E37EA9}")
# Clear messages from Build category
system.clear_messages(CompileCategory)
projects.primary.check_all_pool_objects()
# Get message objects which contain all the data
severities = {
   Severity.FatalError : "Fatal error", Severity.Error : "Error",
   Severity.Warning : "Warning", Severity.Information : "Information",
   Severity.Text : "Text"
msgs = system.get_message_objects(CompileCategory, Severity.FatalError|Severity.Error)
for msg in msgs:
   sev = severities[msg.severity]
   print("{} {}{}: {}".format(sev, msg.prefix, msg.number, msg.text)
Martin
