It is currently Tue Oct 17, 2017 2:46 am
Post new topic  Reply to topic  [ 11 posts ]
 Post subject: Get Variables from GVL
PostPosted: Fri Jan 13, 2017 12:14 pm
Hi all,
I need to get the name of the variables from the GVL of my application in order to perform some check on the names. How can I get these informations?
Should I read the entire GVL file and parse the text line by line? In that case how can I do it?
I'm totally new in this field (execute Python script in Codesys) and I don't know which functions are available...do you have a guide or something similar?
Thank you very much,
Best regards.
Massimo
PostPosted: Fri Jan 13, 2017 2:26 pm
Hi Massimo.
You can export your GVL in PLCopenXML and look for the XML node "globalVars" which represents a GVL. You find the variables below that node.
Here some code for exporting a GVL as PLCopenXML:
class ExportHandler(ExportReporter):
    def error(self, object, message):
        system.write_message(Severity.Error, "Error exporting %s: %s" % (object, message))
    def warning(self, object, message):
        system.write_message(Severity.Warning, "Warning exporting %s: %s" % (object, message))
    def nonexportable(self, object):
        system.write_message(Severity.Information, "Object not exportable: %s" % object)
    @property
    def aborting(self):
        return False;
# Main program
proj = projects.primary
found = proj.find('GVL', True)
assert(found)
gvl = found[0]
reporter = ExportHandler()
print "exporting to string:"
xmldata = gvl.export_xml(reporter)
# or
print "exporting to file:"
gvl.export_xml(reporter, r"c:\Temp\test_gvl.xml")
print "script finished."
For the XML you can use one of the Python modules included in the standard library.
The documentation of the Scripting API is in the file "ScriptEngine.chm" which is in the sub directory "Online Help" of the CODESYS directory.
Martin
PostPosted: Mon Jan 16, 2017 8:12 am
Hi Martin,
Thank you very much for the reply, it is very useful
Best regards.
Massimo
PostPosted: Mon Jan 30, 2017 11:26 am
Hi all,
I'm still in trouble with my project. I only recently tried to perform the operations you suggest but I always got an error (see attachments)
Here's my python code
    @property
    def aborting(self):
        return False;
# Main program
import xml.etree.ElementTree as ET
assert(found)
gvl = found[0]
#print "exporting GVL to string:"
#xmldata = gvl.export_xml(reporter)
print "exporting GVL to file:"
gvl.export_xml(reporter, r"c:/temp/gvl.xml")
print "Parse the file:"
tree = ET.parse("c:/temp/gvl.xml")
print "Get the root:"
root = tree.getroot()
print "Attribute: %s" % (root.attrib)
Every time I run the script I get an error on the parse function (see "XMLError.png"). I tried to modify the file "gvl.xml" removing the first line but the result is the same (see "XMLError2.png")
I checked the file with an XML validator and everything seems ok.
Do you have any suggestion?
Thank you in advance,
Regards.
Massimo
PostPosted: Mon Jan 30, 2017 2:39 pm
Update:
If I try to parse the following file with the same python code I have no problem.
<nodes att="Root node">
   <node1 att="First child">
      <node1Child1 att="Attribute 1"></node1Child1>
      <node1Child2 att="Attribute 2"></node1Child2>
      <node1Child3 att="Attribute 3"></node1Child3>
   </node1>
   <node1 att="Second child">
      <node1Child4 att="Attribute 4"></node1Child4>
      <node1Child5 att="Attribute 5"></node1Child5>
      <node1Child6 att="Attribute 6"></node1Child6>
   </node1>
   <node2 att="Third child">
      <node2Child1 att="Attribute 1"></node2Child1>
      <node2Child2 att="Attribute 2"></node2Child2>
      <node2Child3 att="Attribute 3"></node2Child3>
   </node2>
</nodes>
PostPosted: Mon Jan 30, 2017 4:39 pm
Another update.
It seems the problem lies in the "export_xml" function or in the "reporter" object. I cannot parse either any file or string created by the function. If I try to parse either a file or a string created manually I have no problems.
Furthermore I can parse the xml generated by the "export_xml" function if I create a new file and paste the code in it.
PostPosted: Mon Jan 30, 2017 5:34 pm
Hi Massimo.
Another update.
The problem is the BOM (Byte Order Mark) which the XML writer of .Net automatically adds when writing XML files. You have to remove or skip it before parsing the XML content of the file. Or you can use .Net API which automatically skips the BOM when reading XML files if you run your python script in CODESYS Scripting and IronPython v2.7.x.
I used this workaround when I had to parse a PLCopenXML file generated by CODESYS:
# Load XML file
xmlfile = io.open(r"c:\tmp\test_gvl.xml", "r")
xmlfile.seek(3)
tree = ET.parse(xmlfile)
xmlfile.close()
Martin
PostPosted: Tue Jan 31, 2017 8:47 am
Hi Martin,
Thank you very much, I had no clue about that problem. Now I can read and parse the XML.
I will write soon for another problem :lol:
Regards,
Massimo
PostPosted: Tue Feb 07, 2017 9:39 am
Hi all,
here I'm again. How can I export a visualization page? When I try I get the error:
[INFORMATION]   Object not exportable: ScriptObject{NoDeviceObject, NoExplicitConnectorObject, NoSymbolConfigObject, NoLibManObject, ScriptNoProjectInfoMarker,
NoScriptApplicationObject, ScriptNonTextualObject, NoTaskConfigObject, NoTaskObject, NoImagePoolObject, NoScriptApplicationComposerObject,
NoScriptApplicationComposerObject}(Project=79, Name=VisualizationExportTest, guid=9c501cb8-67a5-4bd8-9172-f67c77d0a324)
Regards.
Massimo
PostPosted: Tue Feb 07, 2017 1:36 pm
Hi Massimo.
No PLCopenXML export for Visualization objecs. You can use the native export but the XML format is not documented.
You can call the method export_native(...) from a common object which allows to export the object and its children or you can call it from a project which allows you to provide a list of objects which you want to export.
Martin
PostPosted: Wed Feb 08, 2017 2:26 pm
Thank you very much.
