It is currently Fri Jul 28, 2017 4:01 pm
PostPosted: Wed Nov 30, 2016 4:54 pm
I'm using the script language to access all types used in a program.
I started with the DevicePrintTree.py as an example and are able to find all types defined in the project.
Some types however are defined in libraries.
I have two problems:
- how can I find the path to the library file in the library manager?
- how can I open the library, while maintaining at the same time the projects.primary project open?
Best regards,
Geert Vanstraelen
PostPosted: Thu Dec 01, 2016 10:09 am
Hi.
The libraries, which are required, are automatically loaded. Even the compiled libraries but they only contain "proxy objects".
for proj in projects.all:
   if proj.primary:
      print("Primary: %s" % proj.path)
   elif proj.library:
      print("Library: %s" % proj.path)
Martin
PostPosted: Thu Dec 01, 2016 6:49 pm
Dear Martin,
Thank you for your solution, the access to projects.all and he path were the missing clues.
The loaded user libraries also seem to contain limited information.
By opening and closing them one by one I finished to have the information that I needed.
Best regards,
Geert
projectPath = ""
libraryPaths = []
print("--- List of all projects: ----------")
   if proj.primary:
      projectPath = proj.path
   elif proj.library:
      if (proj.path.find("compiled") < 0):
         print("********** User library: %s" % proj.path)
         libraryPaths.append(proj.path)
      else:
         print("********** System library: %s" % proj.path)
print("------------------------------------")
for libPath in libraryPaths:
    projects.primary.close()
    lib = projects.open(libPath)
    parsetree(projects.primary, 1, 1)
# Reopen our primary project
projects.open(projectPath)
