It is currently Fri Jul 28, 2017 4:01 pm
PostPosted: Thu Nov 17, 2016 2:36 pm
I would like to set up an automated software build system on a scripting base.
Therefore I start a batch file containing the "codesys --runscript" commands for a python script to compile a codesys project with the option --enablescripttracing.
This works fine, but the trace output is not redirected into a file completely.
On cmd prompt the batch file output ist redirected via "build.bat >> log1.dat" - ok
Within build.bat the python "print()" script commands are redirected via "> log2.dat Codesys --runscript ..." - ok
But the codesys compiler messages are displayed within cmd prompt :|
How can I redirect the messages that come out of codesys during e.g. the python command "app.create_boot_application(bootapppath)" ?
Best regards
Dirk
PostPosted: Thu Nov 17, 2016 5:49 pm
Hi DBe.
Here some example code:
CompileCategory = Guid("{97F48D64-A2A3-4856-B640-75C046E37EA9}")
found = projects.primary.find("Application", True)
app = found[0]
# Clear messages from Build category
system.clear_messages(CompileCategory)
app.create_boot_application(r"C:\Temp\App.app")
# Get message objects which contain all the data
severities = {
   Severity.FatalError : "Fatal error", Severity.Error : "Error",
   Severity.Warning : "Warning", Severity.Information : "Information",
   Severity.Text : "Text"
msgs = system.get_message_objects(CompileCategory)
for msg in msgs:
   sev = severities[msg.severity]
   print("{} {}{}: {}".format(sev, msg.prefix, msg.number, msg.text))
# Or: Get only the message text
msgs = system.get_messages(CompileCategory)
for msg in msgs:
   print(msg)
Martin
PostPosted: Fri Nov 18, 2016 9:38 am
Hi Martin,
thank you very much! The compile information is printed within cmd prompt AND log file now :) .
During project creation I do a SVN checkout (via codesys addon). These reports are printed within cmd prompt only.
Is there another GUID available for this too?
Dirk
PostPosted: Fri Nov 18, 2016 12:22 pm
Hi DBe.
Use the following code to get a list of all available message categories:
guids = system.get_message_categories(False)
for guid in guids:
   print("GUID: {} Description: {}".format(guid, system.get_message_category_description(guid)))
If you replace "False" with "True" in "get_message_categories()" you only get the active message categories.
Martin
PostPosted: Fri Nov 18, 2016 2:08 pm
Hi Martin,
works fine - thank you!
Only one small remark:
"HMI Meldungen" has no constructor? Therefore you algo fails.
But a try-catch filters this.
Dirk
PostPosted: Mon Nov 21, 2016 1:58 pm
Hi DBe.
Which version of CODESYS do you use when this error happened?
Martin
PostPosted: Tue Dec 06, 2016 8:50 am
Hi Martin,
I use Codesys 3.5 SP5 Patch 7 with a build profile 3.5 SP3.
Using these commands:
for guid in guids:
I get these errors:
Skript Meldungen: Information: Build.py(23): Ausnahmefehler (<type 'exceptions.A
ttributeError'>, AttributeError(u'F\xfcr dieses Objekt wurde kein parameterloser
 Konstruktor definiert.',), <traceback object at 0x000000000000002B>)
Skript Meldungen: Information: Build.py(23):       print("GUID: {} Description:
 Konstruktor definiert.',), <traceback object at 0x000000000000002C>)
Kind regards
Dirk
PostPosted: Wed Dec 07, 2016 9:56 am
Hi Dirk.
The problem is not the HMI category. It's only the last working category before the error.
I tried it with two newer versions. With CODESYS V3.5 SP6 the problem still exists. With CODESYS V3.5 SP7 there is no error.
Martin
