It is currently Fri Jul 28, 2017 4:02 pm
PostPosted: Fri Oct 28, 2016 9:32 am
I'd like to use a method from IScripDeviceObject in a "regular" plugin that does not use ScriptEngine yet. Is there a way to get the IScripDeviceObject from IDeviceObject? (Cast does not work.) Or do I have to use ScriptEngine.Execute?
Thanks in advance.
PostPosted: Mon Oct 31, 2016 11:49 am
Hi MSprock.
Which method do you want to use?
Martin
PostPosted: Wed Nov 02, 2016 9:48 am
M.Keller wrote:
Hi MSprock.
Martin
Hi Martin,
the methods are: export/import_io_mappings_from_csv
Best regards
PostPosted: Wed Nov 02, 2016 11:16 am
Hi MSprock.
Your question should normally be send to our support because it is beyond the scope of this forum.
These two methods of the IScriptDeviceObject are just calling the corresponding command with the necessary arguments.
Both commands use the following argument list:
- File path of the CSV file
- Project handle of the project which contains the device
- Object Guid of the device which should import/export its IO mapping
Martin
