It is currently Fri Jul 28, 2017 4:02 pm
PostPosted: Wed Oct 19, 2016 6:06 pm
Hello team.
I need a script to insert a POU below of Application object.
I need too a script to edit a specific POU (MainPrg, for example), i.e., add new variables and modify code of POU.
Finally is necessary deletar a specific POU.
Thanks.
Émerson Butzen
Software Developer
Unisinos/Altus
PostPosted: Thu Oct 20, 2016 8:20 am
Hi butzen.
The Scripting API was extended with the necessary features with CODESYS V3.5 SP9. Look for IScriptIecLanguageObjectContainer and IScriptIecLanguageMemberContainer in the Scripting documentation.
We can only edit Structure Text directly. For the graphical languages you have to import the POU from PLCopenXML or our native format. See IScriptTextualObjectMarker, IScriptObjectWithTextualDeclaration, IScriptObjectWithTextualImplementation and IScriptTextDocument for the textual language and the methods import_xml() and import_native() from IScriptObject2 and IScriptProject2 for the import.
Find the Scripting object, for example with find(), and use the method remove() to delete the object.
Here some example:
proj = projects.primary
found = proj.find("Application", True)
app = found[0]
# Create FB
mypou = app.create_pou("MyPou")
# Change declaration of the FB
implementation = mypou.textual_declaration.replace("""FUNCTION_BLOCK MyPou
VAR_INPUT
   iValue : INT;
VAR_OUTPUT
END_VAR""")
# Change implementation of the FB
mypou.textual_implementation.replace("""iValue := iValue + 1;""")
# Add method to FB
dosomething = mypou.create_method("DoSomething", "INT")
# Change declaration of the method
dosomething.textual_declaration.replace("""METHOD DoSomething : INT
VAR_INPUT
   iVal1 : INT;
   iVal2 : INT;
END_VAR""")
# Change implementation of the method
dosomething.textual_implementation.replace("""DoSomething := iVal1 + iVal2;""")
# Find the pou and delete it
found = app.find("MyPou")
if found and len(found) == 1:
   found[0].remove()
else:
   print("POU 'MyPou' was not found"
Martin
