It is currently Fri Jul 21, 2017 11:36 pm
 Post subject: Adding IO Module to Kbus
PostPosted: Thu Sep 08, 2016 1:36 am
I would like my python script to add an IO Module (8in/8out) to the k-bus. Here is my code:
PROJECT = r"C:\Projects\WAGO_Test.project"
proj = projects.create(PROJECT)
proj.add("CODESYS_Control_for_PFC200",4096,"0000 0013","3.5.8.10")
found = proj.find('CODESYS_Control_for_PFC200', False)
device = found[0]
kbus = device.find('Pfc200Bus', True)[0]
kbus.add('_750-1506', 288, '0000 0001', '3.5.8.10')  #   <-- ERROR HERE
proj.save()
This gives an error however:
'Exception was raised: The device cannot be added or inserted here'
What am I doing wrong?
What method do I use to add an IO device? (I have tried 'kbus.plug =' and that also did not work.)
Thanks!
PostPosted: Thu Sep 08, 2016 10:00 am
Hi WAGOKurt.
I tried to reproduce your scenario and it seems you forgot to add the module ID.
kbus.add('_750-1506', 288, '0000 0001', '3.5.10.0', '880F_750_1506')
Martin
