It is currently Fri Oct 18, 2019 3:46 am
 Post subject: Script SVN Compare
PostPosted: Wed Sep 07, 2016 1:32 pm
Is it possible to perform svn compare
a) for individual objects and get return value if the objects have changes(when compared with a particular revision, say "HEAD") ?
b) a global compare and get handles to objects which have changes(when compared with a particular revision, say "HEAD") ?
I found that the command is currently available in system api
system.commands["svn", "compare"].execute(arg1, arg2, arg3)
Any code snippet and use cases supported in Py would be very helpful
I tried so far
arg1=url , arg2 = revision, arg3 = None / Bool
and got the following error:
Best Regards,
SK
