It is currently Sun Oct 20, 2019 2:59 pm
 Post subject: extern embedded Files
PostPosted: Tue Aug 30, 2016 11:34 am
I want to embedd an extern file with a python script.
I used the workaround mentioned in an other thread to add an object:
-create export of an object to use it as a template.
I see in the export is only the locoation of the file stored, not its content.
But when i delete my embedded object and reimport it with the export file, the altered content of the extern file is not loaded.
It only works when i close the project and open it again, but then the file is not embedded anymore but linked.
Now i also realize that i can not update an embedded extern file without scripting. Neither with using the update function for embedded files nor with adding the altered file again.
As i can not manipulate object content (of txt files for example) nor can i import manipulated objects, what is the right way to get access to the content?
