It is currently Fri Jul 28, 2017 4:01 pm
 Post subject: Updating device version
PostPosted: Fri Aug 26, 2016 2:30 pm
Is it possible to update a version of a device/library in the project by Python?
PostPosted: Tue Aug 30, 2016 1:30 pm
Hi pavo.
Yes and yes.
For the update of a device you use the methods update(...) of the already existing device object. You need the device ID, the device type, the version and, if required, the module ID of the new device. See IScriptDeviceObject.
For the update of a library you need to find the library manager object and replace the library entry in it. That's the way to do it for managed libraries. For a placeholder you can change the default resolution. See IScriptPlaceholderReference.
Some libraries are added and managed by other objects in the project. For example the PLC.
Martin
PostPosted: Fri Dec 16, 2016 4:07 pm
Hello!
Updating a device is clear, but how can i replace/update a library to a defined version (not to newest)?
A look into the script documentation (3.5.8.0) there is only an install_library() and an uninstall_library().
Using this both methods (first uninstall and then install) all my library parameters in the project are gone (default values).
Is there a possibility to get the library parameters before uninstalling the old library?
Is there perhaps a new ScriptEngine 3.5.9.0 with this ILibManager.replace() or ILibManager.update()interface?
To set the libraries to the newest version i use the IScriptProjects4 interface ond open the project with the VersionUpdateFlags.
But here i get DragDrop register exceptions dialogs like in the attachment after calling IScriptProject9.clean_all().
See here http://forum.codesys.com/viewtopic.php?f=18&t=6860&hilit=library+update#p14769
Regards,
Jörg
PostPosted: Mon Jan 02, 2017 12:37 pm
Hi Jörg.
You can get the list of parameters for a library from the property "parameters" from a library reference which you get from the LibMan object.
This example code shows the list of existing parameters of the library reference from the LibMan object and also change some for my test library:
params = library_reference.parameters
   for name in params:
      print "param: %s => %s" % (name, params[name])
      if name.endswith("_SIZE"):
         # set the parameter to new value
         params[name] = "120"
         print "new value of param: %s => %s" % (name, params[name])
ILibMananager is not the LibMan object but the library repository manager of CODESYS. Get the LibMan object of your application or use the one of the Pool and remove the old library reference and add a new one with the required version.
Martin
