It is currently Thu Jul 27, 2017 1:39 pm
Post new topic  Reply to topic  [ 9 posts ]
PostPosted: Sat Jun 18, 2016 6:20 pm
I want to use a python script to add and remove device descriptors. It appears that the IScriptDeviceRepository Interface added in 3.5.9.0 gives me the methods I require, but I've been unable to work out how to get an object that implements the interface.
PostPosted: Sun Jun 19, 2016 12:27 pm
I've got a bit further now, I found a global named device_repository. What I want to do is to ensure that I remove old versions of a set of device descriptors and add in new ones. I've managed to find the devices I want to remove, however either removing or importing devices is giving problems.
devices = device_repository.get_all_devices("MyUniqueText")
for device in devices:
    print("id: ", device.device_id, " info= ",device.device_info.name)
    device_repository.remove_device(device.device_id, None, True)
for file in glob.glob("artefacts/*.devdesc.xml"):
    device_repository.import_device(file, None, True)
    print("Installed "+ file)
Running this gives the error below for the line with remove_device, if I comment that line I get the same for import_device.
System.ArgumentNullException: Traceback (most recent call last):
  File "C:\Users\David\Documents\scripts\CODESYS\CheckoutProject.py", line 50, in <module>
TypeError: Value cannot be null.
Parameter name: source
However the documentation for the source parameter in import_device and remove_device both say
Quote:
Remove the device from this repository source. If null the device is removed from the default repository source.
I've spent quite a while digging through the API's and I haven't managed to work out another value that I could use for the source parameter.
Any help would be much appreciated.
PostPosted: Mon Jun 20, 2016 10:59 am
Hi DavidCozens.
It is a bug. I added the Jira CDS-49921 to our bug tracking, so it will be fixed eventually.
At the moment you need to specify a repository source to import or remove a device/vendor description.
Martin
PostPosted: Mon Jun 20, 2016 2:30 pm
M.Keller wrote:
Hi DavidCozens.
Martin
Hi Martin,
Thank you. I have however been unable to find an API call to give me access to any repository source. How do I find the default repository source?
regards David
PostPosted: Mon Jun 20, 2016 5:15 pm
Hi DavidCozens.
You get the list of repository sources from the property sources (see IScriptRepositorySourceList) of the device repository.
sources = device_repository.sources
mySource = sources["My Device Repository"]
Martin
PostPosted: Mon Jun 20, 2016 7:25 pm
M.Keller wrote:
Hi DavidCozens.
Martin
Hi Martin,
Thank you - I have that part of my script working now.
regards David
PostPosted: Mon Feb 06, 2017 12:55 pm
sorry for capturing this topic, but my question might fit to that.
What's the best way to remove all versions of all devices from the repository, which belong
to a certain vendor?
I did not really find an interface that lists all installed devices of a specific vendor.
Regards
PostPosted: Mon Feb 06, 2017 3:42 pm
Hi jmohre.
The following example code iterates through the device sources, gets a list of all devices for a specific vendor and removes them from the device repository:
try:
   for src in device_repository.sources:
      devs = device_repository.get_all_devices(src)
      devsVendor = devs.get_devices_of_vendor("Some company")
      try:
         for dev in devsVendor:
            device_repository.remove_device(dev.device_id, src, False)
      except:
         print("Failed to remove device description")
finally:
   # Save the device cache because we used the remove_device without
   # saving the device cache because it is faster
   device_repository.save_device_cache()
The call of save_device_cache() is important because otherwise the devices still appear in the repository after a restart of CODESYS but the files of the device were deleted.
Martin
PostPosted: Tue Feb 07, 2017 11:37 am
Thanks Martin,
I found "get_devices_of_vendor" this morning - it is a bit hidden :-).
But I did not take care of the cache issue and the different repositories.
Regards
Jörg
