Hi, when i try to compare two projects I get the message "Die Objekt-GUID xxxxx ist ungültig". Is there a way to find out which Object is it? What does it mean? Thanks
2015-12-11
Can you give some more details?
How do you try to compare the projects? Using a script, or using the normal Project compare?
Hi, right now it was a normal compare project->svn->compare to server project. I made a copy branch abd switch by script and the next step is to compare it to the project in /trunk. Then i get the message when i compare /branch to /trunk.
2015-12-17
MaGu hat geschrieben:
Strange.
Is there a stacktrace available?
(If the script ends with the exception not being caught, the error dialog which appears has a "Details..." button which should show the stack trace.)
Strange.
