It is currently Fri Dec 13, 2019 4:37 pm
PostPosted: Fri Nov 20, 2015 1:39 pm
Is it possible to get intellisense in PTVS for the Codesys Objects like "projects" ... ?
PostPosted: Fri Nov 20, 2015 1:56 pm
Right now, this is not yet possible (except if you create the files yourself).
However, we plan to Implement generating a stub scriptengine.py as part of CDS-23713, which could then be used as a source for intellisense.
PostPosted: Fri Nov 20, 2015 2:30 pm
Thank you for the fast reply !
PostPosted: Wed Jan 27, 2016 7:26 pm
Thanks, that would be very helpful!
PostPosted: Tue Sep 26, 2017 2:51 pm
Hello!
Might I ask if there is any news on this? I can't access the Jira, so I don't know what the status of the mentioned ticket is.
Wouter
PostPosted: Thu Oct 05, 2017 5:45 am
Hello WousV,
Jira ticket is closed - topic is solved.
Solution is in V3.5 SP10 Patch 1.
Greetings,
Matthias
PostPosted: Mon Nov 06, 2017 2:42 pm
I've looked very thoroughly in both V3.5 SP10 Patch1 and V3.5 SP11 Patch 2 and I just can't find what or where this source for Intellisense for PTVS is. Could you please help me?
BR,
Wouter
PostPosted: Tue Dec 05, 2017 9:38 am
Hello
I would also be interested in this.
Is it possible to create a (python) project in visual studio, add a scriptengine to the project and use it as every other .NET assembly with intellisense? Or with some other way. The documentation online is just not very helpfull I think, and the link is broken since ages.
Thanks for the informations.
Greetings
PostPosted: Thu May 17, 2018 1:18 pm
I am also very interested in this topic, is there any new updated information?
PostPosted: Fri Aug 09, 2019 4:33 pm
Has anyone located this scriptengine.py stub? It would be of great help
PostPosted: Wed Nov 06, 2019 2:35 pm
Any update on this topic? I've searched for this file everywhere in my install directory and I can't find it. I'm using Codesys 3.5.14.10.
PostPosted: Mon Nov 11, 2019 10:18 am
Hello everyone,
attached to the issue mentioned by m.schaber there is a .py file.
Executing this script file will generate a api.json (which should work!)
Best regards,
Marcel
PostPosted: Tue Nov 12, 2019 7:55 am
m.prestel wrote:
Hello everyone,
Best regards,
Marcel
Thank you very much! I was able to create the api.json file but I'm kind of stuck now how to continue from this. How can this api give me intellisense in VS?
