It is currently Fri Aug 23, 2019 6:50 am
PostPosted: Mon Nov 23, 2015 11:36 am
I'm using the import_native method to import some files in native export format, by calling it on the project root object.
Even though the files do have some project folder structure in them, import does not use them at all.
Is there any way to make the import_native() method to behave like the import_xml() function concerning folders in the project view?
EDIT:
May this be part of the solution?
viewtopic.php?f=18&t=1890&start=30#p4358
Do i just need to add something to the native export in order to cover the folder structure of that element?
PostPosted: Thu Dec 03, 2015 11:38 am
I just tested it locally, and it worked as expected. (I attached the export file as a zip archive
Untitled4.zip
# create the import reporter
class Handler(NativeImportHandler):
   def conflict(self, name, obj, guid):
      print("Object already exists: ",name)
      return NativeImportResolve.skip
   def progress(self, name, obj, exception):
      print("in progess: ", name)
   def skipped(self, list):
      for obj in list:
         print("Skipped: ", obj.get_name())
def importFilter(name, guid,type,path):
               return True;
handler = Handler()
projects.primary.import_native("D:\\cdsproj\\misc\\untitled4.export", importFilter, handler)
The export file was generated by exporting via the UI.
Could you provide an export file which does not work as expected, and the STR how you generated it?
PostPosted: Tue Sep 11, 2018 6:29 am
M.Schaber wrote:
I just tested it locally, and it worked as expected. (I attached the export file as a zip archive Untitled4.zip.)
      for obj in list:
               return True;
handler = Handler()
While importing am getting the following error, using above method:
(The object GUID '58addc41-f68b-4b7e-82a0-783ded3a2546' is not valid)
