It is currently Tue Feb 18, 2020 8:02 am
PostPosted: Mon Sep 14, 2015 4:19 pm
Is it possible to determine the of objects in the project tree while iterating over them?
I need to distinguish between POUs and Visualization objects for example.
for child in folderobject.get_children():
        if child.is_folder:
            print ('Found folder: {}'.format(child.get_name()))
            export_folder(child)
        else:
            print(child.type)
child.type() will only return these guid, but from my current understanding i have no way tell what kind of object that is?
Thanks in advance
Florian
PostPosted: Mon Sep 14, 2015 5:32 pm
Hi FloWil.
What's the use case behind your question?
Some objects, which are supported by the ScriptEngine, have a special property. For example, the device object has the property "is_device".
Martin
PostPosted: Tue Sep 15, 2015 8:12 am
Yes so i saw the functions for testing for folder and devices.
The use case is exporting of the project, but on a per-file basis.
I basically need to have one POU/Visualisation in one exported file.
This is also why i am not using the recursive export on the project, because it will stop exporting when encountering a subfolder of project. I have this working already for everything code related by using PLCOpenXML-files.
Visualisations do not export to PLCOpenXML though at all as it seems?
So the idea is to export them seperately in native format.
PostPosted: Tue Sep 15, 2015 9:27 am
Hi FloWil.
For POUs you could check the object for the property "has_textual_declaration" because all POU objects have an textual declaration.
I think it is not part of the PLCopenXML specification.
Martin
PostPosted: Wed Apr 10, 2019 10:47 am
Hi Martin,
Martin
Is there a property than can be checked for Visualizations?
Regards,
Daniel
PostPosted: Thu Apr 11, 2019 7:36 am
Hi qbarral.
Sorry, but no.
We have Scripting API for Text List and Image Pool but not for the Visual objects.
Martin
cron
