python two codesys instances
dblessin
2015-06-16
2015-08-12
  • dblessin - 2015-06-16
    is it possible to check with python, if there are other instances of codesys running on the same pc?
    I was not able to find something similar in the Forum.
  • etamgul - 2015-07-16
    If you are interested whether there are other opened projects I think IScriptProjects.all Property is what you are looking for.
    If not, and you want to check that other codesys instances are running than it is a python question,
    maybe http://stackoverflow.com/questions/1632 ... it-windows can answer this or a google search?
  • dblessin - 2015-07-20
    I tested the IScriptProjects.all Property. It's not what I'm searching for, I must check for other codesys instances.
    So I think it's a python question, maybe your link could help me, but at the Moment I don't have the time to test it. I write an answer when I have the time to check it...
