Hello everybody
I need into a project to disable few device and enable some other using a Python script, but Iβm a beginner with this language and I canβt find a solution.
Someone could help me?
Thank you
proj=projects.primaryobjs=proj.find('Device_1', recursive=True)assert(len(objs)==1, 'no or more than one object found')assert(objs[0].is_device, 'object is not a device')device=objs[0]
ifdevice.is_enabled():
Β Β print('disable device...')
Β Β device.disable()else:
Β Β print('enable device...')
Β Β device.enable()
Martin
Thank You so much Martin
Your code works fine
Excuse a last question, something stupid, where can I find the syntax code integrated in Python to handle CoDeSys ? example 'is_device'
Luke
The documentation is in the file "ScriptEngine.chm" in the sub directory "Online Help" of CODESYS. It's not linked to the online help which you can reach directly from CODESYS.
The scripting interface is in the book "_3S.CoDeSys.ScriptEngine.BasicFunctionality Namespace".
Martin
Hello everybody
Thank you
Hi Luke.
Here my sample code:
Martin
Luke
Hi Luke.
Martin
Thank You another time Martin
