SVN branches/tags
MaGu
2015-04-17
2015-05-04
  • MaGu - 2015-04-17
    Hey, is there a way to use the " copy (branch/tag) " command ... and some steps following (switch to new location, increment version numbers, Placeholders...) within python (CODESYS). Thanks!
  • mkeller - 2015-04-17
    Hi.
    The branch/tag commands were simply forgotten for the script interface. We have already an entry in our bugtracking. See SVN-162.
    There are two workaronds:
    • Use the following command where the second parameter (as boolean) specifies if you want to switch to the new branch:
      Zitat:
      system.commands["svn", "copy"].execute("svn://new/destination/url", "false", "commit message")
    • Use the SharpSVN library directly (see attached python file)
    Martin
    testbranch.py [417 Bytes]
  • MaGu - 2015-04-29
    thanks, works fine. One thing. How to switch to the new location? I tried sharpsvn and i tried script interface. What is the best way? I am a little bit confused... path, uri, string, SvnUriTarget...
  • mkeller - 2015-05-04
    Hi MaGu.
    If you use the Copy command you can change the second parameter to "true" for switching immediately after the copy:
    system.commands["svn", "copy"].execute("svn://new/destination/url", "true", "commit message")
    Otherwise you can use one of the switch methods of the project object. Look for IVersionedProject in the scripting documenation.
    Martin
