It is currently Sat Feb 22, 2020 5:04 am
Post new topic  Reply to topic  [ 26 posts ]  Go to page Previous 1 2
PostPosted: Tue Jan 20, 2015 12:23 pm
M.Schaber wrote:
It seems you did mix tabs and spaces in the attached script. The error message actually tells you the location of the problem in the source file.
Python generally interprets tabs according common standards with 8 characters, while your editor seems to use 4 characters of tab with.
Generally, the python community strongly suggests to not mix tabs and spaces in source files:
PEP 8 -- Style Guide for Python Code
You should use an editor which can display tabs and spaces, so you can see the problem. Here is how it looks in my editor using 4 characters tab with:
And here's how the Python interpreter "sees" it using 8 characters tab with:
attachment my scritpt
PostPosted: Tue Jan 20, 2015 12:24 pm
Stil the same probleem
PostPosted: Tue Jan 20, 2015 1:28 pm
Hi.
What error do you get when you execute your script? Is it the text of the assertion or something else?
Martin
PostPosted: Tue Jan 20, 2015 1:44 pm
M.Keller wrote:
Hi.
Martin
PostPosted: Tue Jan 20, 2015 1:45 pm
here post mijn script en error
PostPosted: Tue Jan 20, 2015 2:14 pm
Hi.
The indentation of your script is still wrong. The indentation is important in python. Look at the screenshots.
I modified your script to have the correct indentation and attached it. Please use a proper editor from now on.
Martin
PostPosted: Tue Jan 20, 2015 2:39 pm
M.Keller wrote:
Hi.
Martin
Its stil not working
Thanks voor you time
PostPosted: Tue Jan 20, 2015 8:24 pm
Hi Rahied,
The Device is an EH_IOCA (with underscore).
The name of the plugged devices cannot have a space. You should use e.g. "%s_%d" as device name to make them unique.
Your import file (.txt) should have no empty lines at the end.
Attached an example import file and script for plugging the modules in the Hitachi EH-IOCA EtherCAT slave.
Maybe not perfect or complete, but for me this works.
PostPosted: Fri Sep 04, 2015 8:06 am
By plugging the device via a script a generated name is given to its structures and accessable variables (e.g. "%QX7.7", similarly when one has only plugs the device) but in GUI, I have the chance to map those addresses to variables.
Is there a way to configure the plugged device configuration and I/O mapping ("xxx Configuration" and "xxx I/O Mapping" tabs)?
I have some ADC/DIO/DAC "pins" configured and would like to map their variables and structures to one of the PRGs stored variables.
PostPosted: Tue Sep 08, 2015 12:46 pm
Hi, etamgul,
A scripting interface for the I/O Mapping is currently scheduled for the upcoming V3.5 SP8 release by the end of the year. (See CDS-37756).
(Please note that the schedule may still change when other, more important issues arise.)
PostPosted: Fri Feb 08, 2019 1:57 pm
Hello here is my script.
print "Current project."
proj = projects.primary
PROJECT = r"C:\CoDeSys-Projects\Script-Test.project"
# clean up any open project:
if projects.primary:
projects.primary.close()
print("--- CleanUp finished. ---")
# create a new project
proj = projects.create(PROJECT)
print("--- Project created. ---")
# add PLC
proj.add("CODESYS Control RTE V3",4096,"0000 0002","3.5.5.40")
print("--- PLC Device Insert. ---")
# Create the IO
for dev in proj.get_children():
if dev.is_device:
f = open("C:\Users\RO\Desktop\Import.txt", "r")
for line in f:
tok = line.split(' ')
if "(Master)" in tok[1]:
dev.add(tok[0], DeviceID(64, "0000 0001", "3.5.5.0"))
subnodes = dev.get_children()
master = subnodes[len(subnodes) - 1]
elif "(Slave)" in tok[1]:
master.add(tok[0], DeviceID(65, "51D_0201001000000001", "3.5.4.0"))
elif "(IO)" in tok[1]:
objects = master.find('EH_IOCA', True) # Recursive search
assert(objects and len(objects) == 1, "no object or more than one object with the name EH_IOCA") # Stil have the Error
subnodes = objects[0].get_children(True) # Get all children
# Scenario 1: Plug all
# i = 1
# for node in subnodes:
# name = "%s %d" % (tok[0], i) # Create name with index
# node.plug(name, 68, "51D_00000001_16 Digital Input_16 Digital Input","0")
# i += 1
# Scenario 2: Plug only the first one
if len(subnodes) > 0:
subnodes[0].plug(tok[0], 68, "51D_00000001_16 Digital Input_16 Digital Input","0")
# Save project
proj.save()
# Script finished
print("--- Script finished. ---")
hello Rahied:
I've an another quesiton: how could you know there is a method "add" for proj? I used dir(proj) there was not "add" method listed.
thanks alot
