It is currently Sat Feb 22, 2020 5:20 am
Post new topic  Reply to topic  [ 26 posts ]  Go to page 1 2 Next
PostPosted: Thu Jan 15, 2015 7:01 pm
I would like from a Python script.
I want to add the plug-device of the EH-IOCA (Hitachi).
there is someone who knows how to add plug-device via the Python script.
Rahied
PostPosted: Mon Jan 19, 2015 9:19 am
Hello Rahied.
The following steps are required:
    - Get the slot object, e.g. projectObject.find(...)
    - Plug the device into slot with slotObject.plug(...)
For details about the parameters see the documentation of the ScriptEngine, which you can find in the sub directory "OnlineHelp" of the CODESYS directory.
Martin
PostPosted: Mon Jan 19, 2015 11:45 am
Thanks for your adversely word .
Only I 'm not from there at all . I send my script there. Maybe there is someone who got a example . Or can tell me what to do .
thanks You
:roll: :roll: :roll: :roll: :roll:
PostPosted: Mon Jan 19, 2015 12:04 pm
M.Keller wrote:
Hello Rahied.
Martin
PostPosted: Mon Jan 19, 2015 1:32 pm
thanks You
Hello Rahied.
Martin
PostPosted: Mon Jan 19, 2015 1:58 pm
Hi Rahied.
Please check the ID and the version of the device you want to plug! "51D_00000001_16 Digital Input_16 Digital Input" and "0" could be wrong.
Also check the indentation of the "plug" line in your script because it was wrong when I opened it on my computer.
I added a simple script as an example for you. It plugs all slots with the name "<Empty>". The specified device required a module ID.
Martin
PostPosted: Mon Jan 19, 2015 3:13 pm
M.Keller wrote:
Hi Rahied.
Martin
Tanks M.Keller,
But the next error shows.
PostPosted: Mon Jan 19, 2015 3:15 pm
M.Keller wrote:
Hi Rahied.
Martin
I have a printscreen form the hitachi id code
PostPosted: Mon Jan 19, 2015 3:52 pm
Hi Rahied.
The ID and version are correct.
Since I'm not sure what you want to do, I modified your last script for two different scenarios:
    - Plug all slots with the same device
    - Plug only the first one
Please remove the code of the unused scenario.
Martin
PostPosted: Tue Jan 20, 2015 8:55 am
M.Keller wrote:
Hi Rahied.
Martin
Thanks for your help.
But it's not working.
The next error is when a run the script.
I hoop then you can help me :P :P :P :P :P
PostPosted: Tue Jan 20, 2015 9:11 am
Hello
Sorry, I forgot that find() returns a list. Please replace the code with the following:
objects = master.find('EH_IOCA', True) # Recursive search
assert(objects and len(objects) == 1, "no object or more than one object with the name EH_IOCA")
subnodes = objects[0].get_children() # Get all children
Is there more than one slave below the master? if yes than you have to find a way to find the correct slave.
Martin
PostPosted: Tue Jan 20, 2015 10:51 am
M.Keller wrote:
Hello
Martin
Hello a have put my script en Error code for u.
It's stil not working :twisted: :twisted: :twisted: :twisted:
PostPosted: Tue Jan 20, 2015 11:36 am
It seems you did mix tabs and spaces in the attached script. The error message actually tells you the location of the problem in the source file.
Python generally interprets tabs according common standards with 8 characters, while your editor seems to use 4 characters of tab with.
Generally, the python community strongly suggests to not mix tabs and spaces in source files:
PEP 8 -- Style Guide for Python Code
You should use an editor which can display tabs and spaces, so you can see the problem. Here is how it looks in my editor using 4 characters tab with:
And here's how the Python interpreter "sees" it using 8 characters tab with:
PostPosted: Tue Jan 20, 2015 12:20 pm
PostPosted: Tue Jan 20, 2015 12:21 pm
Hello here is my script.
print "Current project."
proj = projects.primary
PROJECT = r"C:\CoDeSys-Projects\Script-Test.project"
# clean up any open project:
if projects.primary:
projects.primary.close()
print("--- CleanUp finished. ---")
# create a new project
proj = projects.create(PROJECT)
print("--- Project created. ---")
# add PLC
proj.add("CODESYS Control RTE V3",4096,"0000 0002","3.5.5.40")
print("--- PLC Device Insert. ---")
# Create the IO
for dev in proj.get_children():
if dev.is_device:
f = open("C:\Users\RO\Desktop\Import.txt", "r")
for line in f:
tok = line.split(' ')
if "(Master)" in tok[1]:
dev.add(tok[0], DeviceID(64, "0000 0001", "3.5.5.0"))
subnodes = dev.get_children()
master = subnodes[len(subnodes) - 1]
elif "(Slave)" in tok[1]:
master.add(tok[0], DeviceID(65, "51D_0201001000000001", "3.5.4.0"))
elif "(IO)" in tok[1]:
assert(objects and len(objects) == 1, "no object or more than one object with the name EH_IOCA") # Stil have the Error
subnodes = objects[0].get_children(True) # Get all children
# Scenario 1: Plug all
# i = 1
# for node in subnodes:
# name = "%s %d" % (tok[0], i) # Create name with index
# node.plug(name, 68, "51D_00000001_16 Digital Input_16 Digital Input","0")
# i += 1
# Scenario 2: Plug only the first one
if len(subnodes) > 0:
subnodes[0].plug(tok[0], 68, "51D_00000001_16 Digital Input_16 Digital Input","0")
# Save project
proj.save()
# Script finished
print("--- Script finished. ---")
