Login issue if I run a script via --runscript command line
jester
2014-12-08
2014-12-08
  • jester - 2014-12-08
    I am using a batch file to start the SoMachine LogicBuilder via command line and execute a script like
    set SCRIPT=test
    LogicBuilder.exe --nologo --noui --runscript="%SCRIPT%"
    The script itself is running well, I tested it also directly with "Tools -> execute script". But, when I use the same script via command line I get a message window which asking for "username" and "password" => see attached file !
    There is nothing defined or activated regarding user access rights. If the script is started directly within SoMachine this window will not appear ?
    IMG: Login_2014
    Hello, I work now with "online.set_default_credentials('None')" and after some test like to say it is working now. Never the less I do not undertand why this command is necessary ?
