The CODESYS Script Engine runs in the CODESYS IDE, not in the runtime. (It's purpose is to automate development tasks users can also perform manually in the IDE.) Thus, reading and writing variables internally uses the monitoring API of the CODESYS IDE, and cannot be used standalone.
If you want to access variables without a running CODESYS IDE, you may use an external Python interpreter (like the one from
python.org) and one of the OPC Libraries for python you can find on the net. This also requires that you set up an appropriate "Symbol Configuration" within the project, and an OPC server.
To run a python script from ST language, you need to spawn a python interpreter. Depending on your runtime system, you may be able to install a python interpreter there, and start it as an external process. But still, you don't have any communication between the IEC code and python. Another possibility is to use a Server running python, and use tcp/ip from the runtime to connect to the server and communicate.
Technically, it should also be possible to create a runtime module containing a python interpeter (on appropriate platforms). But this option is only available to our OEMs, normal end users usually cannot create runtime modules.
Check out the CODESYS store:
http://store.codesys.com/CODESYS® a trademark of 3S-Smart Software Solutions GmbH
