I'm not sure what you want to accomplish. If it is related to your previous post about a continuous loop inside a test script please give a short description what you want to test.
The following combinations of scripting and Test Manager are possible:
- Test script which executes Python code with the command ExecuteScript from TestManager.Scripting
- Execute a Python script which starts a CODESYS instance with the required parameters for executing a test script
- Execute the (menu) command "Execute Test Script" inside a Python script; requires access to the API of the Automation Platform
I would take the first one and convert the test steps, which should run in a loop, to Python code with the loop around it.
Rough example for a test script:
- Prepare
- Test
- Clean up
Regards,
Martin
thanks for your answer. Yes, it is related to my previous post. I want to test e.g. set/clear I/Os.
I have a test script which executes Python code with the command ExecuteScript from TestManager.Scripting. My Problem is how to execute in Python the test script which contains the I/O-Actions.
Regards,
Malcolm
Malcolm hat geschrieben:
You shouldn't execute a test script from the Python code of another test script. The normal use case would be to use Call or RemoteCall to execute the other test script and the test report of the other one is integrated in the original one. But you need a loop which is not implemented yet.
Are you using the commands from TestManager.Monitoring in that test script? If yes, than you could do the same by using the scripting interface. See read_value(), set_prepared_value(), write_prepared_values() and other methods of the IScriptOnlineApplication.
Regards,
Martin
The documentation is in the file "ScriptEngine.chm" in the sub directory "Online Help" of CODESYS. It's not linked to the online help which you can reach directly from CODESYS.
The scripting interface is in the book "_3S.CoDeSys.ScriptEngine.BasicFunctionality Namespace".
Regards,
Martin
How can I call a testscript with python? I can open a testscript-xml with python but it doesn't run.
Regards,
Malcolm
Hi Malcolm.
- Prepare
- Test
- Clean up
Regards,
Martin
Hi Martin,
Regards,
Malcolm
Hi Malcom.
Regards,
Martin
Where can I find a list of all IScriptOnlineApplication methods?
Regards,
Malcolm
Hi Malcolm.
Regards,
Martin
