To write one or more values through the monitoring you need to get the online application, set/prepare the values and write them through the online application.
The following example prepares one value and writes it to the device:
If you want all the prepared values to be forced you have to use the method force_prepared_values().
For more details you should have a look at the ScriptEngine online help which you can find in the directory "CODESYS\Online Help" of the CODESYS installation directory.
Regards,
Martin
Hi there,
I have a question,
Many Thanks.
Hi.
Regards,
Martin
