It is currently Mon Jun 17, 2019 9:37 am
PostPosted: Thu Dec 19, 2013 6:58 pm
Hi there,
I have a question,
1. How to write a value into a input Function Block(e,g CHxInput) via Test Manager.scripting -> ExecuteScript using Python command?
Many Thanks.
PostPosted: Thu Jan 02, 2014 4:13 pm
Hi.
To write one or more values through the monitoring you need to get the online application, set/prepare the values and write them through the online application.
The following example prepares one value and writes it to the device:
onlineApp = online.create_online_application()
onlineApp.set_prepared_value("PLC_PRG.counter", "5")
onlineApp.write_prepared_values()
If you want all the prepared values to be forced you have to use the method force_prepared_values().
For more details you should have a look at the ScriptEngine online help which you can find in the directory "CODESYS\Online Help" of the CODESYS installation directory.
Regards,
Martin
