I wish to write/select value into a "Value" field such as Off, -10V to 10V, -150mV to 150mV & etc under Module Configuration(Kindly refer to screenshot below), what would the correct scripting command? In future, how would I know which is correct command to use for other purpose I need to use as there is alot of scripting commands in the scripting command help.
Many Thanks.
Anonymous
2013-11-07
Hi, LabView,
labview hat geschrieben:
The functionality to configure device parameters via Scripting was implemented for the issue CDS-22506 which will be released with V3.5 SP4 (currently scheduled for December).
As a side note, the Test Manager already has device parameter configuration functionality.
Reading the help file should be the easiest way to find out what purpose those commands fulfil.
M.Schaber hat geschrieben:
Has anybody a example for this new functionality?
What interface must I use to configure device parameters?
Thanks for the help
Damian
Anonymous
2014-04-03
I did attach two short example scripts to this post.
thank you for the examples, they are very helpful!
Is there any possibility to get "AdditionalInterface" of a connector via python?
Do you have a description of the property parent (IScriptDeviceConnector.parent)?
If I call this property then I get the connectors of the device and not the parent connector of the connector.
If I call "connector.parent" I get the same result as with "device.connectors".
Is this correct?
One side note: The online help "ScriptEngine.chm" is not up to date (I have CoDeSys v3.5 SP4 patch1)!
Best regards
Damian
Anonymous
2014-05-02
Right now, there is no access to the "AdditionalInterfaces" of a connector. If you can describe your use case, I can try to file an improvement.
IScriptDeviceConnector.parent is actually meant do deliver the list of connectors (IScriptDeviceConnectorSet), it is a "parent" in the sense of the object tree, not in the sense of the connector hierarchy. You can iterate over the list and filter for the connector_role property of the IScriptConnector, which can be set to ConnectorRole.parent or ConnectorRole.Child.
For patches, the documentation is usually not updated (exceptions exist).
HTH,
Markus
Hello there,
Many Thanks.
Hi, LabView,
Hi
Thanks for the help
Damian
HTH,
Markus
DeviceParameterTest.py [1.28 KiB]
TestDeviceParameters.py [602 Bytes]
Hi Markus,
Is this correct?
Best regards
Damian
HTH,
Markus
I need the "AdditionalInterfaces" of the parent connector
to know which child connector is valid.
Damian
Hi, Damian,
Your request was filed on our Jira Database as issue CDS-39164, so it will be fixed eventually.
HTH,
M.Schaber
Hi, Damian,
According to current schedule, this issue is likely to be fixed in the Version scheduled for December this year. (Probably V3.5 SP6).
