It is currently Thu Jun 20, 2019 10:52 am
Post new topic  Reply to topic  [ 9 posts ]
PostPosted: Wed Nov 06, 2013 4:12 pm
Hello there,
I wish to write/select value into a "Value" field such as Off, -10V to 10V, -150mV to 150mV & etc under Module Configuration(Kindly refer to screenshot below), what would the correct scripting command? In future, how would I know which is correct command to use for other purpose I need to use as there is alot of scripting commands in the scripting command help.
Many Thanks.
PostPosted: Thu Nov 07, 2013 8:52 am
Hi, LabView,
The functionality to configure device parameters via Scripting was implemented for the issue CDS-22506 which will be released with V3.5 SP4 (currently scheduled for December).
As a side note, the Test Manager already has device parameter configuration functionality.
Reading the help file should be the easiest way to find out what purpose those commands fulfil.
PostPosted: Thu Apr 03, 2014 1:49 pm
Has anybody a example for this new functionality?
What interface must I use to configure device parameters?
Thanks for the help
Damian
PostPosted: Thu Apr 03, 2014 2:33 pm
I did attach two short example scripts to this post.
HTH,
Markus
PostPosted: Tue Apr 08, 2014 12:25 pm
Hi Markus,
thank you for the examples, they are very helpful!
Is there any possibility to get "AdditionalInterface" of a connector via python?
Do you have a description of the property parent (IScriptDeviceConnector.parent)?
If I call this property then I get the connectors of the device and not the parent connector of the connector.
If I call "connector.parent" I get the same result as with "device.connectors".
Is this correct?
One side note: The online help "ScriptEngine.chm" is not up to date (I have CoDeSys v3.5 SP4 patch1)!
Best regards
Damian
PostPosted: Fri May 02, 2014 2:08 pm
Right now, there is no access to the "AdditionalInterfaces" of a connector. If you can describe your use case, I can try to file an improvement.
IScriptDeviceConnector.parent is actually meant do deliver the list of connectors (IScriptDeviceConnectorSet), it is a "parent" in the sense of the object tree, not in the sense of the connector hierarchy. You can iterate over the list and filter for the connector_role property of the IScriptConnector, which can be set to ConnectorRole.parent or ConnectorRole.Child.
For patches, the documentation is usually not updated (exceptions exist).
HTH,
Markus
PostPosted: Wed May 07, 2014 12:13 pm
I need the "AdditionalInterfaces" of the parent connector
to know which child connector is valid.
Damian
PostPosted: Fri May 09, 2014 12:44 pm
Hi, Damian,
Your request was filed on our Jira Database as issue CDS-39164, so it will be fixed eventually.
HTH,
M.Schaber
PostPosted: Tue Jul 08, 2014 1:22 pm
Hi, Damian,
According to current schedule, this issue is likely to be fixed in the Version scheduled for December this year. (Probably V3.5 SP6).
