https://forum.codesys.com/
Automatic parameter change with "Write all values"
https://forum.codesys.com/viewtopic.php?f=18&t=5064
Page 1 of 1
Author:  daniel_REC [ Mon Oct 22, 2012 7:15 am ]
Post subject:  Automatic parameter change with "Write all values"
Currently I'm using Profinet Coupler and with it I can write parameters to module without creating new application, but using "Write all values" button. Is there a way to substitute the mouse click on a button by python script code?
Author:  M.Schaber [ Mon Oct 22, 2012 7:30 am ]
Post subject:  Re: Automatic parameter change with "Write all values"
Currently, this is not possible via Scripting. In our Jira database, the improvement CDS-22506 exists to implement device configuration via scripting. You should ask your support contact to add your company as an interested customer to this issue.
Thank you for your feedback,
Markus Schaber
https://www.phpbb.com/
