In the script engine documentation for V3.5 SP1 Patch 2, I have noticed that a script object factory object is present. Has anyone used this and is able to explain how to use it?
Under ISystem2 members I see a property called "factories", so one should be able to use
system.factories
as an entry point. However, when I try this I get the following error:
Zitat: [INFORMATION] test.py(8): Begin of script [INFORMATION] test.py(8): system.factories [INFORMATION] test.py(8): exception (<type 'exceptions.standarderror'="">, StandardError('Exception has been thrown by the target of an invocation.',), <traceback object="" at="" 0x0000000000000034="">) [INFORMATION] test.py(8): system.factories [INFORMATION] test.py(8): exception (<type 'exceptions.standarderror'="">, StandardError('Exception has been thrown by the target of an invocation.',), <traceback object="" at="" 0x0000000000000035="">) [INFORMATION] test.py(8): system.factories [INFORMATION] test.py(8): Return from script [INFORMATION] test.py(8): system.factories</traceback></type></traceback></type>
Regards,
Frank
Anonymous
2012-09-07
Hi, Frank,
I tried your example, and actually, you found a bug.
I filed the bug into our Jira system as CDS-30637, and fixed it.
The fix is currently scheduled for the next service pack (V3.5 SP2).
Thank you for your feedback!
Markus Schaber
I will be looking forward to try out the feature in SP2 then.
It seems that there will be a lot of new features in the script engine in that version. The documentation in SP1 Patch 2 gives a taster, since it includes documentation for some of the objects that will first be available in SP2 Is SP2 still scheduled to be released during december 2012?
Regards,
Frank
Anonymous
2012-09-17
Yes, the current schedule for V3.5 SP2 is still mid-of-december 2012.
Regards,
Frank
Hi, Frank,
Markus Schaber
Hi Marcus,
Regards,
Frank
