It is currently Mon Sep 23, 2019 7:54 am
PostPosted: Mon Apr 30, 2012 10:12 am
I am wondering if there is a way to add a library manager to a project using scripts. I saw M.Schaber's example to find managers:
Find all library managers in the project:
objects = proj.get_children(recursive=True)
for candidate in objects:
    if candidate.is_libman:
        print(candidate)
I also see the "add_library" in API help, but this methods is for libman objects, so if I have a project without libman I need to create one first. Any tips on how to do this?
Background: I am trying to convert V2.3 libs to V3 using scripts, and after running
proj = projects.convert(oldlib, newlib, "{941937BF-9A12-4174-814E-63D1523C94CC}")
I need to create Library Manager and add necessary libraries.
Best regards,
Frank
PostPosted: Mon Apr 30, 2012 3:23 pm
Hi, Frank,
Currently, there's no direct way, but it is possible to add a library manager using import_native or import_xml. Just manually create one in an empty project and export it using "Project/Export..." or "Project/Export PLCOpenXML...", and then import that file on the application object.
With import_xml, you can also provide the XML inline in the script as a string, without the need for a temporary file.
HTH,
Markus
PostPosted: Tue May 01, 2012 6:46 am
Hi Markus,
Thanks. It worked with import_xml function using the exported XML. :)
I have a little trouble using inline XML; how much of the xml is needed - the complete xml found in exported xml or can I use a shorter syntax? It would be great if you can provide a small example.
Regards,
Frank
PostPosted: Wed May 02, 2012 7:11 am
Hi, Frank,
I'm not an PLCOpenXML expert, so I can't give a definitive answer to that question. Either you use try-and-error to find out which elements can be dropped, or maybe you check the PLCOpenXML Standard.
HTH,
Markus
PostPosted: Wed May 02, 2012 9:50 am
Hi Markus,
Ok. Thanks for the answer (and all your other support) anyway. I just went with having the PLCopenXML in a separate file. :)
Best regards,
Frank
