It is currently Sat Nov 16, 2019 3:15 am
 Post subject: Export XML
PostPosted: Wed Mar 14, 2012 4:18 pm
I want to export the properties of the function block (FB) named "MX_DirectVarAxis".
The function block has properties and methods.
The following script does not work:
import sys
str_PathXmlFile = "C:\\TestScripts\\TestExp.xml"
# create the export reporter
class Reporter(ExportReporter):
def error(self, message):
system.write_message(Severity.Error, message)
def warning(self, message):
system.write_message(Severity.Warning, message)
def nonexportable(self):
print("non exportable")
@property
def aborting(self):
return False
# create the exporter instance.
reporter = Reporter()
proj = projects.primary
obj = proj.find("MX_DirectVarAxis", True)[0]
print obj.get_name()
obj.export_xml(reporter, str_PathXmlFile, True)
The script showed the following messages:
MX_DirectVarAxis
calling(self: IronPython.NewTypes.System.Object#IExportReporter_1$1)
def aborting(self:)
return False
 Post subject: Re: Export XML
PostPosted: Mon Mar 19, 2012 11:18 am
As far as I can see, the script looks fine.
MX_DirectVarAxis
def aborting(self:)
return False
That looks like a trace of a successfull run of the script.
Did you get any error messages or exceptions? Was the TestExp.xml file created?
PostPosted: Tue Mar 20, 2012 10:15 am
The export-file has been created.
But the the properties and methods of the function block are missing. If I try to find a property and to export it as XML-File an error message of the reporter shows, that the property is not exportable.
PostPosted: Tue Mar 20, 2012 11:04 am
Properties alone are not exportable, as properties cannot exist without their parents. If you export manually (via the project menu "Export PLCOpenXML..." command), you cannot select a property without the parent node being selected.
However, POUs should be exported with all their properties etc. if the "recursive" parameter is set to True. In our internal test cases, it works(the PLCOpenXML files contain the properties).
If it is not working for you, it's best if you contact me via our support department, giving detailed steps to repeat (possibly including an example project archive).
