It is currently Sat Mar 23, 2019 12:06 pm
Post new topic  Reply to topic  [ 42 posts ]  Go to page 1 2 3 Next
PostPosted: Thu May 05, 2011 3:03 pm
In this thread we would like to collect samples and recipes to show you how to implement more complex procedures in the CoDeSys script language.
PostPosted: Thu May 05, 2011 3:10 pm
This example is a further development of example 1 from the documentation.
Purpose: To read a controller variable out of an external program or a batch file and to print it on the standard display so that it can be evaluated, e.g.:
C:\Program Files\3S CoDeSys V3.4 SP3\CoDeSys\Common>start /wait CoDeSys.exe --profile="CoDeSys V3.4 SP3" --noUI --runscript="D:\TestScripts\ReadVariable.py"
This is the actual code:
# We use the python 3 syntax for print
from __future__ import print_function
# Our project file is in the data subdirectory of the directory containing
# the script, so we calculate the appropriate path.
import os
scriptdir = os.path.dirname(__file__) # Directory of our script.
datadir = os.path.join(scriptdir, "Data") # Enter the subdirectory.
projectpath = os.path.join(datadir, "Ampel.project") # And add the project name.
# Now, we can open the project.
proj = projects.open(projectpath)
# We fetch the active application.
app = proj.active_application
# And create the online application for it.
onlineapp = online.create_online_application(app)
# We login into the device.
onlineapp.login(OnlineChangeOption.Try, True)
# We start the application, if necessary.
if not onlineapp.application_state == ApplicationState.run:
    onlineapp.start()
# We let the app do its work for some time...
system.delay(1000)
# We read the value of the variable we're interested in.
value = onlineapp.read_value("PLC_PRG.iVar1")
# We output the value to standard output, so our caller can process it.
print(value)
# Last but not least, we clean up.
onlineapp.logout()
proj.close()
In a windows command window, this looks as follows:
C:\Program Files\3S CoDeSys V3.4 SP3\CoDeSys\Common>start /wait CoDeSys --profile="CoDeSys V3.4 SP3" --noUI --runscript="D:\TestScripts\Forum_ReadVariable.py"
------ Build started: Application: Device.App -------
The application is up to date
Build: Information: Size of generated code: 6419 bytes
Build: Information: Size of global data: 2594 bytes
Build: Information: Total allocated memory size for code and data: 10997 bytes
Build: Information: Memory area 0 contains  Data, Input, Output, Memory and Code
: highest used address: 1048576, largest contiguous memory gap: 1037579 (98 %)
Compile complete -- 0 errors, 0 warnings
INT#2263
PostPosted: Thu May 05, 2011 3:14 pm
Expecially when one calls Scripts from the command line interpreter, a possibility to pass parameters to the scripts would be handy.
As a workaroound, one can use environment variables:
import os
print("project to open: ", os.environ["PROJECT"])
# We assert that the application on the device is already running.
proj = projects.open(os.environ["PROJECT"])
onlineapp = online.create_online_application(proj.active_application)
print("variables to read:")
for var in os.environ["VARIABLES"].split(","):
   print ("    ", var, " = ", onlineapp.read_value(var))
This can be launched from a batch file as follows:
@echo off
SET PROJECT=D:\TestScripts\Data\OnlineTest.project
SET VARIABLES=POU.testint,POU.testoutput
start /wait CoDeSys.exe --profile="CoDeSys V3.4 SP3" --noUI --runscript="D:\TestScripts\Forum_Environment.py"
The result looks like this:
C:\Program Files\3S CoDeSys V3.4 SP3\CoDeSys\Common>d:\TestScripts\Forum_Environment.bat
project to open:  D:\TestScripts\Data\OnlineTest.project
------ Build started: Application: CoDeSys_Control_Win_V3.Application -------
Build: Information: Size of generated code: 6453 bytes
Build: Information: Size of global data: 2606 bytes
Build: Information: Total allocated memory size for code and data: 12505 bytes
Build: Information: Memory area 0 contains  Data, Input, Output, Memory and Code: highest used address: 1048576, largest contiguous memory gap: 1036071 (98 %)
variables to read:
     POU.testint  =  INT#1
     POU.testoutput  =  INT#3
PostPosted: Thu May 05, 2011 3:17 pm
Currently, scripts can add devices only via the Device ID. If one doesn't know the ID of a specific device, the following script can help to find out. Just insert the device into the current project, and launch the script:
# Prints out all devices and other objects in the currently open project.
# We enable the new python 3 print syntax
# define the printing function
def printtree(treeobj, depth=0):
    name = treeobj.get_name(False)
    if treeobj.is_device:
      deviceid = treeobj.get_device_identification()
      print("{0} - {1} {2}".format("   "*depth, name, deviceid))
    for child in treeobj.get_children(False):
        printtree(child, depth+1)
for obj in projects.primary.get_children():
   printtree(obj)
print("--- Script finished. ---")
The output looks like this:
- CoDeSys_Control_Win_V3 DeviceID(type=4096, Id='0000 0001', Version='3.4.2.0')
   - CANbus DeviceID(type=15, Id='181015', Version='3.4.2.0')
      - CANopen_Manager DeviceID(type=16, Id='181016', Version='3.4.2.0')
And now you know the Device ID you needed.
PostPosted: Thu May 05, 2011 3:21 pm
Some users want to fetch the starting basis for their projects from a Subversion repository.
The following example (which is similar to Example 4 in the documentation) creates a new project, and adds a device via PLCOpenXML.
# Imports a Device in PLCOpenXML from Subversion via command line svn client.
import sys, os
# some variable definitions:
SVNEXE = r"C:\Program Files\Subversion\bin\svn.exe"
XMLURL = "file:///D:/testrepo/testfolder/TestExport.xml"
PROJECT = r"D:\test.project"
# clean up any open project:
if projects.primary:
   projects.primary.close()
# Fetch the plcopenxml data from subversion.
# The 'with' construct automatically closes the open pipe for us.
with os.popen('"' + SVNEXE + '" cat ' + XMLURL, 'r') as pipe:
   xmldata = pipe.read()
# create a new project:
proj = projects.create(PROJECT)
# create the import reporter
class Reporter(ImportReporter):
   def error(self, message):
      system.write_message(Severity.Error, message)
   def warning(self, message):
      system.write_message(Severity.Warning, message)
   def resolve_conflict(self, obj):
      return ConflictResolve.Copy
   def added(self, obj):
      print("added: ", obj)
   def replaced(self, obj):
      print("replaced: ", obj)
   def skipped(self, obj):
      print("skipped: ", obj)
   @property
   def aborting(self):
      return False
# create the importer instance.
reporter = Reporter()
# import the data into the project.
proj.import_xml(reporter, xmldata)
# and finally save. :-)
proj.save()
The subversion command line client which is needed for the script above is available for free from several providers. The Subversion Download Page contains links to some of them, the Cygwin-Project contains another one.
PostPosted: Tue Aug 02, 2011 1:31 pm
Example snippets: Quickly finding library managers:
Find all library managers in the project:
objects = proj.get_children(recursive=True)
for candidate in objects:
    if candidate.is_libman:
        print(candidate)
The quick way is via list comprehension:
managers = [i for i in proj.get_children(True) if i.is_libman]
Or via the filter function:
managers = filter(lambda i: i.is_libman, proj.get_children(True))
If you are only interested in the top level library manager (the one in the POU view), you set recursive to False.
Remind that you can also search under a specific device or application if you call get_children on that object instead of the project.
PostPosted: Tue Aug 02, 2011 1:42 pm
About the device ID (for automatically inserting devices to your project):
Since 3.4.4.0 you can go to the information tab of the device which shows all details like type, ID and version.
This makes it much easier than first creating a script to get this information.
PostPosted: Tue Aug 02, 2011 2:05 pm
It seems you're right, but unfortunately, it seems that module IDs are not displayed there. :cry:
PostPosted: Thu Oct 06, 2011 9:50 am
Hi hi,
i was trying to understand the following code:
import os
but I recieve always the following error: NameError: name 'projects' is not defined
could u help please and tell me how to correct it?
Thank you
PostPosted: Fri Oct 07, 2011 9:45 am
This statement enables the python 3 syntax for print (See the python documentation for more details). I use this syntax so that this script can run with both Python 2 and python 3 without modifications.
import os
This code calculates the location of the project "Ampel.project" relative to the directory where the script itsself is. It assumes that in the directory containing the script file there is a subdirectory "Data" containing the "Ampel.project" file. This just happens to be the directory layout I used for my internal test scripts.
"projects" is an object imported into the namespace for scripts running in CoDeSys, so it is only available if your script is being started in CoDeSys directly (either via the "Execute Script" menu command or button, or via the "--runscript" command line parameter.)
For modules imported by your scripts, this automatic injection does not take place because it would break some modules from the standard library. Simply add "from scriptengine import *" at the top of your module.
If you run the script from outside of CoDeSys (for example in the py.exe or ipy.exe interpreters, or an IDE like IDLE or Eric), it won't work, since the codesys environment is not available there.
But remember that you can start CoDeSys with the "--runscript" and "--NoUI" parameters to execute python scripts within CoDeSys. (See the documentation for more information.)
PostPosted: Fri Oct 07, 2011 2:35 pm
Hi Hi,
thank u for the reply.
"If you run the script from outside of CoDeSys (for example in the py.exe or ipy.exe interpreters, or an IDE like IDLE or Eric), it won't work, since the codesys environment is not available there."
I run the script from IDLE! It means it won't work.
I want actually to export a xml-file with python. I have a CoDeSys-Project named Test.project. The first step ist to open this project, which i did with "os.startfile". The second step is to export the xml-file directly from python.
Could you give some tips??
PostPosted: Fri Oct 07, 2011 3:01 pm
Yes. If you run the script from IDLE, it has no way to access the CoDeSys functionality. The CoDeSys ScriptEngine is not a bunch of ordinary python modules, but a so-called hosted environment, that means the Python interpreter is embedded (and deeply integrated) into the CoDeSys application.
Ah, now I see. Your current approach would require the Python script from IDLE to magically recognize the running CoDeSys instance, and then send the commands to that application. Unfortunately, that is not how it currently works. (Note that os.startfile() gives you no way to wait for the application to finish startup and loading, so you would not know when you could actually start to send commands to CoDeSys.)
What you currently could do is something like
os.system(r'c:\Path\to\CoDeSys.exe --runscript="c:\Path\to\CoDeSysScript.py"')
and use an environment variable to pass the name of the CoDeSys project to the script. (See viewtopic.php?p=3803#p3803 for an example of parameter passing via environment variables.) Then, in the CoDeSysScript.py, you can load the project and export the files.
PostPosted: Mon Oct 10, 2011 10:09 am
Hi M.Schaber,
if i use the code: os.system(r'c:\Path\to\CoDeSys.exe --runscript="c:\Path\to\CoDeSysScript.py"' and in my CoDeSysScript.py should only open the project Test.project; is it fine to use os.startfile()??? or is there a better command to load the project?
Another question: what is the difference between using PLCOpenXML and using the native Export format of CoDeSys?
Thanks a lot.
PostPosted: Mon Oct 10, 2011 10:25 am
Hi, Aoj,
Inside the CoDeSysScript.py, do not use os.startfile(). That will start a second instance of codesys loading the project, and you still don't have control over that second instance.
You need to open the project and do the export from within the CoDeSysScript.py. This may look like:
# .. initialization skipped
proj = projects.open(PathToProject)
device = proj.find('_3S_Testspec_Device')[0]
device.export_xml(reporter, ExportFileName, recursive = True)
projects.open, and the find and export_xml methods are provided by the CoDeSys environment.
PLCOpenXML is a standardized format for interchange of data between independent IEC-61131 implementations. Due to that, it is interoperable with other software, but it is not lossless (some aspects may be lost if you export in that format).
The native Export format is CoDeSys-specific and less human-readable, but it is lossless.
So if you only use those exported objects for re-importing them into CoDeSys later, you use the native format. If you want to process those files using 3rd-party tools, you should use the PLCOpenXML format.
PostPosted: Mon Oct 10, 2011 12:44 pm
Thank you for the explanation about the difference between the PLCOpenXML and the native export format.
in a previous post we talked about the error: "NameError: name 'projects' is not defined".
you said i can correct this error by adding "from scriptengine import *" at the top of the module in condition i am starting CoDeSys with the "--runscript".
after adding "from scriptengine import *", i get the following error: "ImportError: No module named scriptengine" !!!!
